Burned up a set of brand new Accel spark plug wires
#1613975
04/29/14 11:01 PM
04/29/14 11:01 PM
Posts: 53 Connnecticut
acesneights
Connnecticut
I just put new 8mm Accel wires on my Travco(Dodge)motorhome with 440. I put 200 miles on it and most of the spark plug boots melted ?? Any ideas ?
1975 Dodge Travco 440 BB
1972 Dodge Travco 318 SB
Re: Burned up a set of brand new Accel spark plug wires
[Re: ChinooK440]
#1613979
04/30/14 08:24 PM
04/30/14 08:24 PM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
if your running headers you just might have to run some heat sleeves or wires with better quality boots .
if your burning wires that quick with manifolds you have a tuning issue like a lean fuel mixture or not enough ignition timing advance. Big , steep geared rv,s make lots of heat and are really hard on plug wires.
I did this on my motorhome with new headers(very little room). I used the boot/wire sleeves and they worked awesome. Never had a bit of trouble in 3 years.
[Re: ChinooK440]
#1613980
05/02/14 09:26 AM
05/02/14 09:26 AM
Posts: 1,795 Greer, SC
TooMany62s
Greer, SC
try these: http://www.summitracing.com/parts/the-14260/overview/
