Re: NOX on My LA car
[Re: Tropicalcats]
#1613031
04/28/14 01:27 PM
04/28/14 01:27 PM
Challenger 1
Cincinnati, Ohio
Talking with a guy this weekend and he said my LA 70 Challenger should have had NOX on the carb. Is that right? I do have the ECS system. When I got the car the carb had been replaced so can't tell if the solenoid shad been on the original. Thanks
The NOX system monitored the speed of the vehicle through the speedo cable and retarded the timing. It did not affect the carb I don't think. The timing vacuum controller did mount to one carb stud.
Here's a picture of the harness of one when I restored my car. This mounts on the firewall on the passenger side.
I put it back on my car to cover the hole in my firewall.
[Re: Tropicalcats]
#1613033
04/28/14 02:07 PM
04/28/14 02:07 PM
Posts: 1,652 Calgary, Alberta Canada
m46rat
This would only be the case IF the car was delivered to a location in California when new. Otherwise it will not have that system on it. Your fender tag should have N97 on it if it were indeed the case.
[Re: Challenger 1]
#1613035
04/28/14 03:06 PM
04/28/14 03:06 PM
Posts: 27,474 So Cal
autoxcuda
So Cal
The NOX system monitored the speed of the vehicle and retarded the timing. It did not affect the carb I don't think. The timing vacuum controller did mount to one carb stud.
What was the original motor on you gold 71 Challenger?
Not all 71 Ccalifornia cars got a Nox system. Depended on motor and trans. And they varied some per model and trans.
[Re: autoxcuda]
#1613036
04/28/14 06:22 PM
04/28/14 06:22 PM
Challenger 1
Cincinnati, Ohio
318/904 when it was new, 71
[Re: Tropicalcats]
#1613041
04/29/14 01:26 PM
04/29/14 01:26 PM
autoxcuda
So Cal
And with all that said, my 70 LA car which has ECS had an after market NOX system put on that from the booklet was mandatory by the state of California.
I think I have at least one 2nd gen Barracuda dash fascia with that sticker pasted right onto it. I always thought it was tacky when they stuck that sticker right on the dash staring at the driver all the time.
There's another emissions related sticker on the windsheild you see. IIRC, it's from "Consumer Affairs" and says exempt on it I think. Our family's 1970 Vista Cruiser still has it on it.
[Re: Tropicalcats]
#1613042
04/29/14 08:13 PM
04/29/14 08:13 PM
Posts: 974 www.mmcdetroit.com
MMC Detroit
www.mmcdetroit.com
Harness for speed control. I have a perfect original harness and I'm trying to find some one to make it from this pattern.
MMC/ ICCA Detroit.
The Motor City or where ever there is Mopars
[Re: ScottSmith_Harms]
#1613044
04/30/14 01:52 AM
04/30/14 01:52 AM
autoxcuda
So Cal
Dave M&H will help you with that. I have a good one from a 71 Challenger if ypu need it.
Was it from a 318 or 340 car? 383HP car?
I didn't see any signs of this on my 71 383HP auto car. And I haven't on any other california 71 383HP's. But they do get removed.
[Re: Tropicalcats]
#1613046
05/01/14 12:45 AM
05/01/14 12:45 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
LOL - back in the day when a car changed ownership you had to install a NOX kit to register your car. It's just a vacuum advance retarder. Cars with multiple carbs or cold air induction were exempt.
Today the NOX upgrade isn't needed because the cars older than 1975 are smog check exempt.
[Re: 383man]
#1613049
05/11/14 12:42 AM
05/11/14 12:42 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I understand people want the NOX system if the car is being restored to stock but do most who restore to all stock actually want it to work ? Myself I would gut the solenoid so I have vacum advance all the time as I am sure it hurt milage also. With the solenoid gutted you could still have it all hooked up and looking correct. And this was before EGR was installed as I believe we did not see the first type of EGR system until 72 or 73. Ron
A well placed BB inside each vacuum hose will effectively bypass it.
