Towing a race trailer help #1611972
04/25/14 03:47 PM
04/25/14 03:47 PM
Rudolph, Ohio
moparguy7074 Offline OP
Rudolph, Ohio
Hey guys, need some help. I just bought a really nice mh, but the frame isn't quite up to the task of towing my 10,000# car/trailer combo. I'm looking for one of those assist wheel setups. What do you guys use?
Re: Towing a race trailer help [Re: moparguy7074] #1611973
04/25/14 04:16 PM
04/25/14 04:16 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sorry but even with a trailer toad, it's going to put a lot stress on the back of your RV. It will cause all kinds of trouble back there, imo. Plus the power is not there to tow a 10k trailer plus the RV. Even with a trailer toad you need to have full frame welded on back there, but you still won't have the engine power needed, sorry.
I have lot's of experience towing race trailers and I hate to give you the bad news.
I stepped up to a toterhome in 2002.
Re: Towing a race trailer help [Re: Challenger 1] #1611974
04/25/14 05:03 PM
04/25/14 05:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I put a class 5 hitch on mine and found a "like new" Trailer Toad and love it. I talked to Bob Jones who owns a trailer dealership and he said go with this model. I almost ordered a new one but after talking to the guy that owns Trailer Toad he said I could go with the older smaller tired model.
http://www.trailertoad.com/
10,000 pounds is a lot to tow so you may have to box the rear frame section too if the motorhome has the power and the braking ability to handle the weight.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Towing a race trailer help [Re: moparguy7074] #1611975
04/25/14 07:19 PM
04/25/14 07:19 PM
If it is a Unibody motorhome chassis don't tow with it
Re: Towing a race trailer help [Re: moparguy7074] #1611976
04/25/14 07:21 PM
04/25/14 07:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What kind of motorhome is it? A class A, C or Super C. Gonna guess class C or A puller. FWIW I tow all over the west with a Class A pusher and have no issues at all except climbing some of the big hills where I am slowed to 45. Otherwise no issue and if I were in the Midwest would have no issue running 75+
Re: Towing a race trailer help [Re: Al_Alguire] #1611977
04/25/14 08:27 PM
04/25/14 08:27 PM
Cincinnati, Ohio
Cincinnati, Ohio
Doesn't a class A puller or pusher have a full frame?
I assumed he had a class C with a gas engine when he mentioned the "frame isn't quit up"... Class C usually have smaller engines I thought. I could be wrong.
Re: Towing a race trailer help [Re: Challenger 1] #1611978
04/25/14 08:38 PM
04/25/14 08:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Many of the class A pullers are built on basically HD pickup truck chassis so I would not think they would be suitable as is for a lot of heavy towing as there is not much frame there. Where as the pushers are better equipped frame wise, depending on chassis.
Re: Towing a race trailer help [Re: Al_Alguire] #1611979
04/26/14 07:20 AM
04/26/14 07:20 AM
Rudolph, Ohio
Rudolph, Ohio
It's a 2001 Four Winds Hurricane 31' Class A puller. V-10 Ford engine. Ihe frame goes clear to the back, but the last 2' is poorly welded to the rest. I can strengthen it to make it work. The bad part is it has a shorter wheelbase with approximately 9' behind rear wheels, which from what I'm told will flex and cause issues no matter how much I reinforce the frame.
Re: Towing a race trailer help [Re: moparguy7074] #1611980
04/26/14 02:09 PM
04/26/14 02:09 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I tow with a 97 Four Winds 31' C-class. Its on an E-SuperDuty chassis with air-assist bags in the rear. and a full frame extension to the bumper. Not the same as your A-class, but the powertrain would be the same. I wouldn't want to try to tow 10k with it! I just have an open trailer, roughly 5k lbs with my car on it and it tows that pretty well.
To be honest, I think 10k may just be too much for a triton V10 thats already worked pretty hard pulling the chassis alone. the '01 & newer Ford has the 5-spd. transmission, and I've heard that helps alot with towing because the V10 likes to rev. A toad may help the chassis with the weight, but I'm skeptical about the long term ability of that powerteam to do the job you're asking it to. I think the job you're looking at really requires a FRED or a D-pusher, if you want it to last at all.
Re: Towing a race trailer help [Re: moparguy7074] #1611981
04/26/14 02:24 PM
04/26/14 02:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With 9' behind the axle its gonna flex the frame and
body pretty good even with the toad... it would still
have the side to side load... I put another X brace
on the back of my Rampage chassis so I could pull
a LIGHT small trailer.. without it, it would have
flexed the body
Re: Towing a race trailer help [Re: MR_P_BODY] #1611982
04/27/14 11:03 AM
04/27/14 11:03 AM
Rudolph, Ohio
Rudolph, Ohio
I found what I was looking for, but the price!! www.tufftow.com
Re: Towing a race trailer help [Re: moparguy7074] #1611983
04/27/14 12:09 PM
04/27/14 12:09 PM
PA.
"Little"John
"Little"John
PA.
If you have your mind made up on a Tuff-Tow I may know where you can get a used one if the guy still has it. Its not far from me in PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Towing a race trailer help [Re: pittsburghracer] #1611984
04/27/14 01:06 PM
04/27/14 01:06 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
box the rear frame, X brace it, use a
weight distributing hitch, load the trailer so the tongue weight is not too heavy, put a sway reducer on the hitch, forget about the towd, you'll be fine. Been there done that.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
