Re: Towing a race trailer help
[Re: moparguy7074]
#1611973
04/25/14 04:16 PM
04/25/14 04:16 PM
Challenger 1
Cincinnati, Ohio
Hey guys, need some help. I just bought a really nice mh, but the frame isn't quite up to the task of towing my 10,000# car/trailer combo. I'm looking for one of those assist wheel setups. What do you guys use?
Sorry but even with a trailer toad, it's going to put a lot stress on the back of your RV. It will cause all kinds of trouble back there, imo. Plus the power is not there to tow a 10k trailer plus the RV. Even with a trailer toad you need to have full frame welded on back there, but you still won't have the engine power needed, sorry.
I have lot's of experience towing race trailers and I hate to give you the bad news.
I stepped up to a toterhome in 2002.
[Re: Challenger 1]
#1611974
04/25/14 05:03 PM
04/25/14 05:03 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I put a class 5 hitch on mine and found a "like new" Trailer Toad and love it. I talked to Bob Jones who owns a trailer dealership and he said go with this model. I almost ordered a new one but after talking to the guy that owns Trailer Toad he said I could go with the older smaller tired model. http://www.trailertoad.com/10,000 pounds is a lot to tow so you may have to box the rear frame section too if the motorhome has the power and the braking ability to handle the weight.
[Re: moparguy7074]
#1611976
04/25/14 07:21 PM
04/25/14 07:21 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
What kind of motorhome is it? A class A, C or Super C. Gonna guess class C or A puller. FWIW I tow all over the west with a Class A pusher and have no issues at all except climbing some of the big hills where I am slowed to 45. Otherwise no issue and if I were in the Midwest would have no issue running 75+
[Re: Al_Alguire]
#1611977
04/25/14 08:27 PM
04/25/14 08:27 PM
Challenger 1
Cincinnati, Ohio
Doesn't a class A puller or pusher have a full frame?
I assumed he had a class C with a gas engine when he mentioned the "frame isn't quit up"... Class C usually have smaller engines I thought. I could be wrong.
[Re: Challenger 1]
#1611978
04/25/14 08:38 PM
04/25/14 08:38 PM
Al_Alguire
Las Vegas
Many of the class A pullers are built on basically HD pickup truck chassis so I would not think they would be suitable as is for a lot of heavy towing as there is not much frame there. Where as the pushers are better equipped frame wise, depending on chassis.
[Re: moparguy7074]
#1611980
04/26/14 02:09 PM
04/26/14 02:09 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I tow with a 97 Four Winds 31' C-class. Its on an E-SuperDuty chassis with air-assist bags in the rear. and a full frame extension to the bumper. Not the same as your A-class, but the powertrain would be the same. I wouldn't want to try to tow 10k with it! I just have an open trailer, roughly 5k lbs with my car on it and it tows that pretty well. To be honest, I think 10k may just be too much for a triton V10 thats already worked pretty hard pulling the chassis alone. the '01 & newer Ford has the 5-spd. transmission, and I've heard that helps alot with towing because the V10 likes to rev. A toad may help the chassis with the weight, but I'm skeptical about the long term ability of that powerteam to do the job you're asking it to. I think the job you're looking at really requires a FRED or a D-pusher, if you want it to last at all.
[Re: moparguy7074]
#1611981
04/26/14 02:24 PM
04/26/14 02:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It's a 2001 Four Winds Hurricane 31' Class A puller. V-10 Ford engine. Ihe frame goes clear to the back, but the last 2' is poorly welded to the rest. I can strengthen it to make it work. The bad part is it has a shorter wheelbase with approximately 9' behind rear wheels, which from what I'm told will flex and cause issues no matter how much I reinforce the frame.
With 9' behind the axle its gonna flex the frame and body pretty good even with the toad... it would still have the side to side load... I put another X brace on the back of my Rampage chassis so I could pull a LIGHT small trailer.. without it, it would have flexed the body
[Re: pittsburghracer]
#1611984
04/27/14 01:06 PM
04/27/14 01:06 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
box the rear frame, X brace it, use a weight distributing hitch, load the trailer so the tongue weight is not too heavy, put a sway reducer on the hitch, forget about the towd, you'll be fine. Been there done that.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
