906 valve job #1611103
04/23/14 06:26 PM
04/23/14 06:26 PM
Chester, VA
tobnHisglory Offline OP
Chester, VA
Hey guys, I have a set of 906 heads and 2.14/1.81 valves. They are at the machine shop but I am going back and forth with the shop owner about the valve job. I want a steep 75 degree throat cut on the intake but he is scared to cut them because of the bulge in the bowl for rocker oiling. He is afraid a 75 degree cut down from the valve seat will break through. Anything special to watch for or advice on what I should tell the machinist. He is a chevy guy and I'm getting aggravated.
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: 906 valve job [Re: tobnHisglory] #1611104
04/23/14 06:37 PM
04/23/14 06:37 PM
Chester, VA
Chester, VA
A 75 degree bottom cut is completely normal with 2.14 intake valves in a 906/915, right? I'm not just momentarily losing my mind?
-Reggie
Re: 906 valve job [Re: tobnHisglory] #1611105
04/23/14 06:45 PM
04/23/14 06:45 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I have no real idea my friend, hope others more educated than I chime in here.
Until then here's a set of 915's I won't take any farther for you to eyeball
Re: 906 valve job [Re: roadhazard] #1611106
04/23/14 06:53 PM
04/23/14 06:53 PM
Chester, VA
Chester, VA
Thanks roadhazard. Those ports look great! That's where I'm hoping to be soon if I can ever get the machine work done. What you have removed in porting is well beyond the 75 degree cut I want done.
-Reggie
Re: 906 valve job [Re: roadhazard] #1611107
04/23/14 07:02 PM
04/23/14 07:02 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Them shure is purtty
Re: 906 valve job [Re: GTX MATT] #1611108
04/23/14 08:03 PM
04/23/14 08:03 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a shot of my 906's I did for my old 440. I had used a 70 degree stone and then I worked and blended the bowl area. Ron
Re: 906 valve job [Re: 383man] #1611109
04/23/14 08:56 PM
04/23/14 08:56 PM
Chester, VA
Chester, VA
Thanks Ron. I knew I wasn't crazy. At least not about this
-Reggie
Re: 906 valve job [Re: tobnHisglory] #1611110
04/23/14 10:51 PM
04/23/14 10:51 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No problem as I am glad to help. I did forget to say they are 2.14 and 1.81 valves I put in them. Ron
Re: 906 valve job [Re: tobnHisglory] #1611111
04/23/14 11:02 PM
04/23/14 11:02 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If he don't believe you just have him look at the picture, Lol
Thanks for the compliments guys! It was the first set of heads I've ported and seem to perform as well as they look
Re: 906 valve job [Re: tobnHisglory] #1611112
04/24/14 12:21 PM
04/24/14 12:21 PM
Chester, VA
Chester, VA
Heading to the shop later today to talk to the machinist and show these pics if necessary. Thanks again everyone.
-Reggie
Re: 906 valve job [Re: tobnHisglory] #1611113
04/24/14 06:56 PM
04/24/14 06:56 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Do yourself a HUGE favor: Take them to a guy that KNOWS 906 heads.
I'd seek out someone who does (good running) stock and S/S heads.
Re: 906 valve job [Re: cudadoug] #1611114
04/24/14 10:56 PM
04/24/14 10:56 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
The short turn is very important in a 906. Adding big valves makes the problem worse. The short turn needs to be lowered considerably when you are done
Re: 906 valve job [Re: scatpacktom] #1611115
04/25/14 12:09 AM
04/25/14 12:09 AM
Chester, VA
Chester, VA
Thanks for the advice guys. I would have taken them to a better shop, but I don't know anyone locally who deals a lot with mopars I am familiar with making a nice rounded off radius from the bottom cut bellow the valve seat to the floor. I've done that on few sets I ported in the past but I've never lowered the floor there very much. How far into the short turn do you extend the radius to lower floor? I have always been leery of breaking through so I don't go back very far.
Do you guys suggest more of a round radius, consistent in shape from floor to valve job, or a radius that tapers off slower and longer as it approaches the floor? I may need to draw a picture to make sense of what I'm saying... Thanks guys!
-Reggie
Re: 906 valve job [Re: tobnHisglory] #1611116
04/25/14 12:50 AM
04/25/14 12:50 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I was taught to also make the walls at the floor right at the short turn a little wider to slow up the air to make the turn.. But not sure if that's correct nowadays
Re: 906 valve job [Re: ademon] #1611117
04/27/14 11:08 AM
04/27/14 11:08 AM
Vermont
bracketcharger Offline
Vermont
Any chance of you folks posting some more pictures . Looking for pix of the radius into the port floor. I'm porting a set of 452 heads and I could use all the info your willing to share. Thanks.
