Re: Before mating the transmission to the engine should I.
[Re: RAUPLEMINZE454]
#1610252
04/21/14 07:31 PM
04/21/14 07:31 PM
Posts: 26,026 Rio Linda, CA
John_Kunkel
Rio Linda, CA
One quart is enough to lube the insides until the pump fills it on startup.
[Re: John_Kunkel]
#1610253
04/21/14 08:20 PM
04/21/14 08:20 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Put some ATF on the snout that goes into the trans also.I also put a bit on the seal.Rocky
Chrysler Firepower
[Re: stumpy]
#1610256
05/03/14 11:28 PM
05/03/14 11:28 PM
RapidRobert
If the front pump seal ain't new on this deal I would highly suggest installing a new one & I pack the back side where the spring is with vaseline so the spring stays in place as you are (carefully) tapping it in place
