Time for a new 8-3/4 differential #1609929
04/20/14 03:49 PM
04/20/14 03:49 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The hot rod let all the smoke out of the differential.
I was planning on stuffing this in the Imperial but that's a no go now.
Since it's out I might as well put a new part in it. What's the best way to go with this thing? There are a TON of lockers and limited slip units out there and I haven't really looked into them until now. I do need to keep price in mind on this.
Which unit would you guys recommend?
Things to consider:
5,100 lbs of Imperial.
NOT a drag car.
Sock 440 for now but it might inherit a bit more power.
Extremely long wheelbase will be even more difficult to maneuver with a locker.
- Stu Harmon
Re: Time for a new 8-3/4 differential [Re: feets] #1609930
04/20/14 03:51 PM
04/20/14 03:51 PM
Kirkland, Washington
Pacnorthcuda Offline
Find a power lock, or buy a new Torsen Tru-Trac. The Torsen is about $550.a power lock is less, but you gotta find it, then plan on $80 for new clutches.
Re: Time for a new 8-3/4 differential [Re: Pacnorthcuda] #1609931
04/20/14 04:10 PM
04/20/14 04:10 PM
Davis, California, USA
MrBelvedere2 Offline
Rick (E-Booger) always touts the eaton true-trac diff. He says they work/act just like a factory mopar sure grip but are way better than the cluth or cone type diffs.
1965 Plymouth Belvedere II hardtop
Re: Time for a new 8-3/4 differential [Re: MrBelvedere2] #1609932
04/20/14 05:30 PM
04/20/14 05:30 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
The TrueTrac is the unit I've got my eye on.
- Stu Harmon
Re: Time for a new 8-3/4 differential [Re: feets] #1609933
04/20/14 07:02 PM
04/20/14 07:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
You wont be disapointed.
I am truckless..
Re: Time for a new 8-3/4 differential [Re: 340SHORTY] #1609934
04/21/14 12:19 AM
04/21/14 12:19 AM
I'm going to be putting a true-trac in my 65 belvedere when the time comes to rebuild the diff...paint and body first though.....
Re: Time for a new 8-3/4 differential [Re: MrBelvedere2] #1609935
04/21/14 12:27 AM
04/21/14 12:27 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
That's in the plans for my Bee, as well.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Time for a new 8-3/4 differential [Re: Pacnorthcuda] #1609936
04/21/14 12:31 AM
04/21/14 12:31 AM
dogdays Offline
dogdays  Offline
Well, if you can find a Torsen, that'd be interesting, as Torsen doesn't list one for the 8 3/4 in its literature.
But the Tru-Trac is being produced for the 8 3/4.
R.
Re: Time for a new 8-3/4 differential [Re: dogdays] #1609937
04/21/14 01:17 AM
04/21/14 01:17 AM
R.
The Eaton Tru-trac IS a Torsen differential. Yes, for about $550 you get one.
http://www.drivetrainshop.com/eaton_true...pect-in-custody
Re: Time for a new 8-3/4 differential [Re: feets] #1609938
04/21/14 10:44 AM
04/21/14 10:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Dr Diff 575.When I get the Dana going Ill probally order one from him.Rocky
Chrysler Firepower
Re: Time for a new 8-3/4 differential [Re: therocks] #1609939
04/21/14 11:00 AM
04/21/14 11:00 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I've got a Dana 60 from Cass with the tru trac. Sold the 8 3/4 before I owned "2 of them" LOVE IT! For the cost of getting a good 8 3/4 gear pot built ..... I just went with the Dana and was done with it
Re: Time for a new 8-3/4 differential [Re: brads70] #1609940
04/21/14 05:33 PM
04/21/14 05:33 PM
dogdays Offline
dogdays  Offline
R-O-N-G!!!!!
The Eaton Tru-trac and the Torsen ARE DIFFERENT AND COME FROM DIFFERENT COMPANIES.
Look it up before you make ignorant statements.
They have always been competitors, since the early '80s. They have never been produced by the same company.
Now do they function the same, yes. And do the gears in the T2 Torsen look like a Tru-trac? Yes. But they have their own patent.
And the gears in the original Torsen which they now call the T1, don't look anything like the Tru-Trac.
R.
Re: Time for a new 8-3/4 differential [Re: dogdays] #1609941
04/21/14 07:52 PM
04/21/14 07:52 PM
R-O-N-G!!!!!
R.
Jeez....calm down. How about "Torsen Style Differential: as in helical gear. Does that make you happy? Life's too short to get upset.
"http://www.drivetrainshop.com/eaton_truetrac_s/139.htm" The word "Torsen" is being used to describe True-Tracs, everyone knew what was meant.
