Time for a new 8-3/4 differential
#1609929
04/20/14 03:49 PM
04/20/14 03:49 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The hot rod let all the smoke out of the differential. I was planning on stuffing this in the Imperial but that's a no go now. Since it's out I might as well put a new part in it. What's the best way to go with this thing? There are a TON of lockers and limited slip units out there and I haven't really looked into them until now. I do need to keep price in mind on this. Which unit would you guys recommend? Things to consider: 5,100 lbs of Imperial. NOT a drag car. Sock 440 for now but it might inherit a bit more power. Extremely long wheelbase will be even more difficult to maneuver with a locker.
Re: Time for a new 8-3/4 differential
[Re: Pacnorthcuda]
#1609931
04/20/14 04:10 PM
04/20/14 04:10 PM
Posts: 649 Davis, California, USA
MrBelvedere2
Rick (E-Booger) always touts the eaton true-trac diff. He says they work/act just like a factory mopar sure grip but are way better than the cluth or cone type diffs.
1965 Plymouth Belvedere II hardtop
[Re: MrBelvedere2]
#1609932
04/20/14 05:30 PM
04/20/14 05:30 PM
feets
Senior Management
Senior Management
Irving, TX
The TrueTrac is the unit I've got my eye on.
[Re: 340SHORTY]
#1609934
04/21/14 12:19 AM
04/21/14 12:19 AM
MrBelvedere2
I'm going to be putting a true-trac in my 65 belvedere when the time comes to rebuild the diff...paint and body first though.....
[Re: feets]
#1609938
04/21/14 10:44 AM
04/21/14 10:44 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Dr Diff 575.When I get the Dana going Ill probally order one from him.Rocky
Chrysler Firepower
[Re: dogdays]
#1609941
04/21/14 07:52 PM
04/21/14 07:52 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
R-O-N-G!!!!! The Eaton Tru-trac and the Torsen ARE DIFFERENT AND COME FROM DIFFERENT COMPANIES. Look it up before you make ignorant statements.
They have always been competitors, since the early '80s. They have never been produced by the same company.
Now do they function the same, yes. And do the gears in the T2 Torsen look like a Tru-trac? Yes. But they have their own patent. And the gears in the original Torsen which they now call the T1, don't look anything like the Tru-Trac.
R.
Jeez....calm down. How about "Torsen Style Differential: as in helical gear. Does that make you happy? Life's too short to get upset. "http://www.drivetrainshop.com/eaton_truetrac_s/139.htm" The word "Torsen" is being used to describe True-Tracs, everyone knew what was meant.
