Page 5 of 7 1 2 3 4 5 6 7
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609686
04/21/14 12:31 PM
04/21/14 12:31 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
thanks for taking the time to post those Scott. saved them all as a reference for my engine.
Re: 1971 340 Cuda Engine Paint Details [Re: chrisf] #1609687
04/21/14 12:43 PM
04/21/14 12:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
No problem, if any of you need more of something specific just ask.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609688
04/21/14 06:47 PM
04/21/14 06:47 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I think this should go into the Tech Archive.
Re: 1971 340 Cuda Engine Paint Details [Re: denfireguy] #1609689
04/21/14 07:29 PM
04/21/14 07:29 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Scott put up a lot of great info here!
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609690
04/22/14 11:42 AM
04/22/14 11:42 AM
pa.
dan9 Offline
dan9  Offline
pa.
Thanks for the great detail pics. I am just curious in this pic did you mean belt or bolt? I was wondering why you would change a bolt for show or street use.
Re: 1971 340 Cuda Engine Paint Details [Re: dan9] #1609691
04/22/14 11:46 AM
04/22/14 11:46 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Belt, just a typo
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609692
04/24/14 10:58 AM
04/24/14 10:58 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Scott
My 1970 Duster 340 had the same oil pressure sending unit as yours. It is an automatic car. The engine also had a Prestolite dual point distributor that I switched out when I was in high school.
I didn;t inspect the sending unit for date codes. I always assumed it was original to the engine.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 1971 340 Cuda Engine Paint Details [Re: FJR doc] #1609693
04/24/14 01:45 PM
04/24/14 01:45 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
My oil sending unit has 80 on one flat and G0 on another.What would be the date code?Are these replateable?
Re: 1971 340 Cuda Engine Paint Details [Re: 5carguy] #1609694
04/24/14 01:53 PM
04/24/14 01:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The G0 is the date (July 1970). Yes I can replate them (I did that to my example pictured). As far as which style is correct manual vs auto, the auto versions Ive seen were the more compact style. Im not sure why.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609695
04/25/14 02:35 PM
04/25/14 02:35 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Good information...thanks!
Re: 1971 340 Cuda Engine Paint Details [Re: 1972CudaV21] #1609696
04/27/14 12:09 PM
04/27/14 12:09 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Scott so is the negative cable painted on the engine like a big block?
Re: 1971 340 Cuda Engine Paint Details [Re: Mopucky] #1609697
04/27/14 02:01 PM
04/27/14 02:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not on an orange painted engine (Windsor Plant) but I've seen evidence that points towards blue engines (Mound Road) having been painted with the cables attached, same goes for plug wire plastic looms
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609698
04/27/14 02:59 PM
04/27/14 02:59 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Great thanks for the info. I'm having it painted now. I'll try posting pics when it's done.
Re: 1971 340 Cuda Engine Paint Details [Re: Mopucky] #1609699
04/27/14 08:27 PM
04/27/14 08:27 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I was looking at the oil sending unit in your picture and noticed the bell housing bolts had lock washers on them.Any chance of a picture of the bolt heads? My car came with a scattershield.
Re: 1971 340 Cuda Engine Paint Details [Re: 5carguy] #1609700
04/27/14 08:39 PM
04/27/14 08:39 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Sure, here are a few, this is an original paint engine, absolutely original bolts, etc. ........And no, it's not an "H" head like all of the supposedly "OE correct" engine fastener kits come with
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609701
04/27/14 08:40 PM
04/27/14 08:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Reverse wire clip
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609702
04/27/14 08:40 PM
04/27/14 08:40 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bell
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609703
04/27/14 08:53 PM
04/27/14 08:53 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
You are a wealth of information sir.I thank you very much.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609704
05/02/14 06:17 PM
05/02/14 06:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
More pics to follow soon
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609705
05/02/14 08:02 PM
05/02/14 08:02 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I can't wait.Bring them on
