Page 1 of 7 1 2 3 4 5 6 7
1971 340 Cuda Engine Paint Details #1609606
04/19/14 08:49 PM
04/19/14 08:49 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Hi, I am in the process of assembly and painting the engine in my 71 Cuda. It is a 340 4 speed with Air Conditioning.
I'm looking for pics and info on what needs to be bolted on the engine for paint, especially timing cover/water pump bolts and washers. I want to get this as close to factory as possible. I have seen that some bolts were panted and backed off to put on brackets. Any pics/info will be greatly appreciated!
Re: 1971 340 Cuda Engine Paint Details [Re: Mopucky] #1609607
04/19/14 09:00 PM
04/19/14 09:00 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Some other info will help others answer your questions with engine details:
What is the SPD date of the car?
Is the car N95 california emissions?
Re: 1971 340 Cuda Engine Paint Details [Re: autoxcuda] #1609608
04/19/14 09:58 PM
04/19/14 09:58 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Fender tag build date on car is 104
No N94 emissions on tag
Re: 1971 340 Cuda Engine Paint Details [Re: Mopucky] #1609609
04/19/14 10:09 PM
04/19/14 10:09 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, you should have an orange engine assembled at the Windsor Ontario plant. Here are a few that might get you on your way. This shows all of the parts which were attached before the engines were painted. Those two straps you see with the chains connected to them are original factory engine handling straps. A few of these were left on engines (likely by mistake) and I searched around and scrounged them up so I could paint the engine leaving the appropriate bare areas that they covered small areas on the ends of the heads while the engine was painted.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609610
04/19/14 10:10 PM
04/19/14 10:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
After paint.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609611
04/19/14 10:11 PM
04/19/14 10:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
With most or the small parts added
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609612
04/19/14 10:12 PM
04/19/14 10:12 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609613
04/19/14 10:13 PM
04/19/14 10:13 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There are A LOT of small unique details on these engines, date codes, part#'s, etc. The choke is stamped "75" as are the reproductions, however, the reproductions lack the second smaller stamping which is "BA 148". The choke rod is also stamped with a tiny "527". Reproductions are blank.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609614
04/19/14 10:25 PM
04/19/14 10:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here are a batch of some of the smaller details
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609615
04/19/14 10:25 PM
04/19/14 10:25 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609616
04/19/14 10:26 PM
04/19/14 10:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609617
04/19/14 10:27 PM
04/19/14 10:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609618
04/19/14 10:28 PM
04/19/14 10:28 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609619
04/19/14 10:29 PM
04/19/14 10:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
E
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609620
04/19/14 10:29 PM
04/19/14 10:29 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609621
04/19/14 10:30 PM
04/19/14 10:30 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609622
04/19/14 10:31 PM
04/19/14 10:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609623
04/19/14 10:31 PM
04/19/14 10:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
This is an NOS date coded Alternator belt. It's only going to see show use, I'll be putting a reproduction on for street duty.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609624
04/19/14 10:32 PM
04/19/14 10:32 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609625
04/19/14 10:33 PM
04/19/14 10:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
K
