Page 3 of 7 1 2 3 4 5 6 7
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609646
04/19/14 09:47 PM
04/19/14 09:47 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
So far all leads on the correct dip stick color point to black paint being correct. I was starting to think they were bare steel but based on a few good survivors and an NOS version I found, they were painted (likely dipped) in black paint which was very thin and flaked off easily so most went south in a hurry leaving a bare steel handle.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609647
04/19/14 09:48 PM
04/19/14 09:48 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The heater hose bracket bolt (as well as many other attaching bolts holding a non painted part to the engine) were black/gray phosphate.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609648
04/19/14 09:49 PM
04/19/14 09:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
A8
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609649
04/19/14 09:49 PM
04/19/14 09:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Reproduction heater hoses have the correct shape and features but the ink stampings need some work. The ink easily wipes off if you lay hands on it, and it's too bright white and chalky looking. Original stampings were a deeper shade of white and were far more durable when handled or cleaned, the lettering sheen was more like that of the rubber hose and was not chalky looking.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609650
04/19/14 09:50 PM
04/19/14 09:50 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct restored original DR1114429 Idle Stop Solenoid. The stamping is very difficult to view once installed as the stamping faces the intake.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609651
04/19/14 09:51 PM
04/19/14 09:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
B2
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609652
04/19/14 09:51 PM
04/19/14 09:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That often missing black spring clip is to hold the idle stop solenoid power wire.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609653
04/19/14 09:52 PM
04/19/14 09:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Original sate code correct restored 4 Speed Oil sending unit, automatic cars use a smaller more compact style.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609654
04/19/14 09:53 PM
04/19/14 09:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
B5
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609655
04/19/14 09:54 PM
04/19/14 09:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
B6
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609656
04/19/14 09:55 PM
04/19/14 09:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Original temp sender was installed after paint. All are stamped 250 on one side, the opposite side has the two digit date code. These were date coded with a letter for the month and a number for the year, example J0 = September 1970
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609657
04/19/14 09:56 PM
04/19/14 09:56 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
B8
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609658
04/19/14 09:57 PM
04/19/14 09:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
NOS PS hose, plating was not high quality, this came out of an original sealed box. Date code is the day of the year and the year. 021 = 21st day, 0 = 1970
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609659
04/19/14 09:58 PM
04/19/14 09:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The other end has the part#
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609660
04/19/14 09:58 PM
04/19/14 09:58 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Most 1971 340's had the 294 stamped pan. These pans came two ways, with pan rail stiffeners in the corners, and without. My survivor engine didn't have them.
Paint coverage was poor on the bottoms of the oil pans, there are typically bare spots near the center of the bottom of the pans simply because the factory painters didn't usually make any effort to paint the underside. My survivor happens to have good coverage on the bottom so I copied it on my clone stroker engine and covered most of it.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609661
04/19/14 09:58 PM
04/19/14 09:58 PM
Washington/Las Vegas
1971 Gran Coupe Offline
I visited Scott the other day and the motor looks good in the pictures, but up close and personal, the resto job is awesome!! This should answer anyones questions on painting the 340.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609662
04/19/14 09:59 PM
04/19/14 09:59 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
71 TQ throttle cable nuts were typically silver and the stud was black phosphate, the opposite of many other Mopars of the day.
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609663
04/19/14 10:00 PM
04/19/14 10:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
C4
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609664
04/19/14 10:00 PM
04/19/14 10:00 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
C5
Re: 1971 340 Cuda Engine Paint Details [Re: ScottSmith_Harms] #1609665
04/19/14 10:01 PM
04/19/14 10:01 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
C6
