Thanks Scratch and BulletBob #1606438
04/12/14 08:21 PM
04/12/14 08:21 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
I scored a set of van bucket seats that are as close to new as can be from my friend at the local landfill. Bob supplied with a set of Ramcharger bases and scratch sent me the correct promatic shifter handle for a pickup. I know the seats are not color coordinated but just getting the cab in order is a big step. I'll either dye them or get a set of red seat covers down the road. Heres a few pick of the junkyard truck interior.
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606439
04/12/14 08:22 PM
04/12/14 08:22 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
the other side
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606440
04/12/14 09:46 PM
04/12/14 09:46 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
RED . Thats the big reason I sold my 88 short wide box truck 3 years ago. but Scratch and Bob are ok in my book too.
I am truckless..
Re: Thanks Scratch and BulletBob [Re: 340SHORTY] #1606441
04/13/14 01:26 AM
04/13/14 01:26 AM
scratchnfotraction Offline
are those high back seats? how do they fit around the rear glass area?
I know a flip base with tall back seat on pass side will knock the glass out in a pick up...but not sure what and how that goober installed the bases either?
Re: Thanks Scratch and BulletBob [Re: scratchnfotraction] #1606442
04/13/14 02:06 AM
04/13/14 02:06 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Mike I installed the drivers seat with the existing adjuster and a 3/4" spacer on the rear attachment studs. On the passenger side, there was no adjustment mechanism so I made a rail out of 1 1/2" square tubing and also a 3/4" spacer in the rear. Of course the passenger side is not adjustable but it clears the rear glass at least an inch and a half. I could've redrilled the mounting holes in the floor pan to move both forward; but this will suffice in the meantime. I installed large fender washers underneath but maybe late I will make up a solid plate to tie all 4 mounting holes together for piece of mind. Again, thanks a lot Bud.
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606443
04/13/14 02:08 AM
04/13/14 02:08 AM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
High backs; here's a pix
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606444
04/13/14 04:12 AM
04/13/14 04:12 AM
Central TX
roe Offline
roe  Offline
Central TX
Very nice, clean install. Hopefully one day I can have my interior look as good as yours does.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606445
04/13/14 12:41 PM
04/13/14 12:41 PM
kool info on mounting them they look really nice. the new look on them is awsome in the pics so I know they are nice up close.
glad someone gets some use out of the only good part of that shifter. that longer handle for the trucks is just right.
give yours some time Roe. it will shape right up.
Re: Thanks Scratch and BulletBob [Re: scratchnfotraction] #1606446
04/13/14 07:30 PM
04/13/14 07:30 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Thank you for the how to on making them fit a reg cab The other 5 pairs of bases that I have will get used for sure now with a set leftover in my other trucks
Larry they look great in there
Re: Thanks Scratch and BulletBob [Re: BulletBob] #1606447
04/14/14 03:40 PM
04/14/14 03:40 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
On the passenger side I drilled the holes in the square tubing to mount to the seat and then drilled holes about 2 inches back to mount the tubing to the seat base.
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606448
04/14/14 08:58 PM
04/14/14 08:58 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
Found a new Dodge mini van center console that was taken out at the dealership on Ebay for $21.00. Exact same color as the seats and I couldn't beat the price.
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606449
04/14/14 09:18 PM
04/14/14 09:18 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
now all you need is some gray door panels and visors, black dash, carpet and a interior paint job.
I am truckless..
Re: Thanks Scratch and BulletBob [Re: 340SHORTY] #1606450
04/14/14 09:27 PM
04/14/14 09:27 PM
the 88 truck I just picked up has some nice grey door panels and a nice no a/c grey dash. seat looks faded light blue but must be a cloth grey most likely.. nice with no tears so it fits my azz better than the one I gots now for sure.
Re: Thanks Scratch and BulletBob [Re: 340SHORTY] #1606451
04/14/14 09:54 PM
04/14/14 09:54 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
I'll dye or cover them down the road; right now I am just looking to tie up a few loose ends so I can drive it with a little comfort. All the mechanicals are done with paint and body work left. Got the rest of my life to do that It's a sleeper the way it is with the 512 in it and it's a lot more fun when I pull away from the chebys and ferds....they never expect it from this old man in a beat up truck
Re: Thanks Scratch and BulletBob [Re: scratchnfotraction] #1606452
04/14/14 09:56 PM
04/14/14 09:56 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
hmm gray door panels might be different with a 2 tone interior
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606453
04/27/14 09:20 PM
04/27/14 09:20 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
There's a pair on RamChargerCentral
Re: Thanks Scratch and BulletBob [Re: BulletBob] #1606454
11/27/14 04:39 AM
11/27/14 04:39 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Larry, I'm getting ready to copy your mod
Re: Thanks Scratch and BulletBob [Re: BulletBob] #1606455
11/27/14 09:47 AM
11/27/14 09:47 AM
Re: Thanks Scratch and BulletBob [Re: Hemi_Ram] #1606456
11/27/14 05:52 PM
11/27/14 05:52 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I acutally like the white seats. It sort of offsets all the red that drowns the cabin. It's great to hear members helping members!
Re: Thanks Scratch and BulletBob [Re: MuuMuu101] #1606457
11/28/14 09:57 PM
11/28/14 09:57 PM
Pennsylvania
Red 79 Offline
Red 79  Offline
Pennsylvania
I have a set of gray door panels for those year trucks. They cover the entire inside door from top to bottom and are in excellent condition if anyone needs them just PM me.
Tom
