Which starter should I be looking for? #1606419
04/12/14 08:02 PM
04/12/14 08:02 PM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
Hey guys,
I am looking for a starter for my brother's 1971 Demon. The engine is a 1995 Magnum 360 and the trans is a 727 out of a 1970 Duster 340. What type of starter should I be looking for? I think I have heard that some material may have to be removed from the block to clear for installation?
Thanks in advance,
Brian
Re: Which starter should I be looking for? [Re: RAUPLEMINZE454] #1606420
04/12/14 08:08 PM
04/12/14 08:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just buy a mini starter for the magnum engine.
Re: Which starter should I be looking for? [Re: stumpy] #1606421
04/13/14 12:59 AM
04/13/14 12:59 AM
IN
ahy Offline
ahy  Offline
IN
Agree a Magnum starter for say a 92 360 should work fine. Parts store new or premium reman. Sometimes there is a terminal extension that needs to be removed from the + post but no biggie.
Re: Which starter should I be looking for? [Re: RAUPLEMINZE454] #1606422
04/13/14 01:48 AM
04/13/14 01:48 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I'm gonna guess a starter for a 95 Magnum 360 should fit with minimal mods Just a guess though
Re: Which starter should I be looking for? [Re: ahy] #1606423
04/13/14 11:28 AM
04/13/14 11:28 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
91 up V6 or V8 will work fine. Work best if the plastic wiring adapter is removed.
Re: Which starter should I be looking for? [Re: Dcuda69] #1606424
04/13/14 12:34 PM
04/13/14 12:34 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I'll go way out into left field too and back you up on this one.
Mo' Farts
Moderated by "tbagger".
Re: Which starter should I be looking for? [Re: Grizzly] #1606425
04/18/14 07:37 PM
04/18/14 07:37 PM
McHenry, Illinois
McHenry, Illinois
I just wasn't sure if the 727 would some how interfere, thanks for the help guys.
So are there companies you guys go through or just a reman starter from the local parts store?
Re: Which starter should I be looking for? [Re: RAUPLEMINZE454] #1606426
04/18/14 07:39 PM
04/18/14 07:39 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Parts store is fine.
Re: Which starter should I be looking for? [Re: stumpy] #1606427
04/18/14 07:45 PM
04/18/14 07:45 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
tti or dougs headers?
I run pretty much only mini starters on everything. If you have the above headers, there is a short and long body. You need to get the short body. Usually a 318 dakota is good for a starter.
I get them on 1/2 off day at pick and pulls.
I agree, take the plastic extension off the positive post.
Re: Which starter should I be looking for? [Re: RobX4406] #1606428
04/18/14 07:50 PM
04/18/14 07:50 PM
McHenry, Illinois
McHenry, Illinois
Neither, they are Heddman HTC long tubes
