Page 3 of 3 1 2 3
Re: triple purpose build questions [Re: Bad340fish] #1605905
04/13/14 05:01 PM
04/13/14 05:01 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
Billy, those chinese aluminum heads you got, can you buy them not ported by dr j i believe you bought them from??
Re: triple purpose build questions [Re: Bad340fish] #1605906
04/13/14 06:51 PM
04/13/14 06:51 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Look for a Cummins 4bt with an inline pump. That would be my all time fav diesel swap candidate into old iron.
Mopar to the bone!!!
Re: triple purpose build questions [Re: 72Swinger] #1605907
04/13/14 07:30 PM
04/13/14 07:30 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I was going to suggest this, but it doesn't look like many are making enough reliable power to push a brick into the 11's
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: triple purpose build questions [Re: MR_P_BODY] #1605908
04/14/14 02:39 AM
04/14/14 02:39 AM
Chester, VA
tobnHisglory Offline
Chester, VA
Mr P Body, I would love to hear more details about that slant 6 diesel conversion. That is a build thread I would love to see. Was this something you did recently? Please tell me you have pictures.
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: triple purpose build questions [Re: sixpackgut] #1605909
04/14/14 09:49 AM
04/14/14 09:49 AM
gregsdart Offline
gregsdart  Offline
I was thinking maybe a 8.8 rear out of an explorer for the van if its wide enough
If you research it, there is a very narrow 8.8 out of a special option Ranger that comes with the 31 spline axles, discs,posi, and good gear ratios from the factory. They are rare, but come about 56.5 wheel mount to wheel mount. The regular Explorers rears come with Discs, posi, a good selection of gears and are 59.5 wide. I have one under a 1965 dart with 2006 Mustang GT optional 18x8.5 rims and tires, with only a spring relocate. If you go this route, grab everything that you can off the donating vehicle. The companion flange, the bolts that hold it on, and the brake lines, two from the pass side. Take a look at the axles where the seals run, those are prone to wear and leak, but can be fixed with relocate bearings available. The pinion seal can be fixed with a thin repair sleeve that slides over the damaged area. Pull the rear cover and look for rust as well to make sure it didn't get damaged from rust. If you buy it right, this is about as good a deal on a rear axle swap as there is.
Re: triple purpose build questions [Re: tobnHisglory] #1605910
04/14/14 10:14 AM
04/14/14 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was working for Chrysler and they built it up for
a lighter weight diesel... but that project was dropped
Re: triple purpose build questions [Re: MoparBilly] #1605911
04/14/14 10:34 AM
04/14/14 10:34 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Same van?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: triple purpose build questions [Re: sixpackgut] #1605912
04/14/14 11:28 AM
04/14/14 11:28 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
The small block "Air Wolf" heads are the Pro Comp casting which come in at 170CCs unported, 191ccs with Pro Comp's CNC job, and 220ccs with Dr J's porting.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: triple purpose build questions [Re: MoparBilly] #1605913
04/14/14 07:01 PM
04/14/14 07:01 PM
Charleston
Charleston
Weight on the title says 3300 lbs. The van i'm buying is longer than that pink one. I will be bringing it home tomorrow
Re: triple purpose build questions [Re: sixpackgut] #1605914
06/17/14 12:20 AM
06/17/14 12:20 AM
Charleston
Charleston
Some pics
Re: triple purpose build questions [Re: sixpackgut] #1605915
06/17/14 12:22 AM
06/17/14 12:22 AM
Charleston
Charleston
Re: triple purpose build questions [Re: sixpackgut] #1605916
06/17/14 12:27 AM
06/17/14 12:27 AM
Charleston
Charleston
Re: triple purpose build questions [Re: sixpackgut] #1605917
06/17/14 12:32 AM
06/17/14 12:32 AM
Charleston
Charleston
Re: triple purpose build questions [Re: sixpackgut] #1605918
06/17/14 12:33 AM
06/17/14 12:33 AM
Charleston
Charleston
Bar
Re: triple purpose build questions [Re: sixpackgut] #1605919
06/17/14 12:35 AM
06/17/14 12:35 AM
Charleston
Charleston
I need a 408 now
Re: triple purpose build questions [Re: sixpackgut] #1605920
06/17/14 07:43 AM
06/17/14 07:43 AM
Q
Quicktree Offline
Quicktree  Offline
Q
awesome, better make sure none of the booze is open
Re: triple purpose build questions [Re: sixpackgut] #1605921
06/17/14 11:37 AM
06/17/14 11:37 AM
an8sec70cuda Offline
That looks awesome Ray! See ya this afternoon.
CHIP
'06 GMC 2500HD LBZ Duramax
Page 3 of 3 1 2 3
