Re: triple purpose build questions
[Re: Bad340fish]
#1605905
04/13/14 05:01 PM
04/13/14 05:01 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Billy, those chinese aluminum heads you got, can you buy them not ported by dr j i believe you bought them from??
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Bad340fish]
#1605906
04/13/14 06:51 PM
04/13/14 06:51 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Look for a Cummins 4bt with an inline pump. That would be my all time fav diesel swap candidate into old iron.
Mopar to the bone!!!
[Re: MR_P_BODY]
#1605908
04/14/14 02:39 AM
04/14/14 02:39 AM
Posts: 198 Chester, VA
tobnHisglory
Chester, VA
Mr P Body, I would love to hear more details about that slant 6 diesel conversion. That is a build thread I would love to see. Was this something you did recently? Please tell me you have pictures.
-Reggie tobnHisglory2000@aol.com Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4 Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
[Re: sixpackgut]
#1605909
04/14/14 09:49 AM
04/14/14 09:49 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I was thinking maybe a 8.8 rear out of an explorer for the van if its wide enough
If you research it, there is a very narrow 8.8 out of a special option Ranger that comes with the 31 spline axles, discs,posi, and good gear ratios from the factory. They are rare, but come about 56.5 wheel mount to wheel mount. The regular Explorers rears come with Discs, posi, a good selection of gears and are 59.5 wide. I have one under a 1965 dart with 2006 Mustang GT optional 18x8.5 rims and tires, with only a spring relocate. If you go this route, grab everything that you can off the donating vehicle. The companion flange, the bolts that hold it on, and the brake lines, two from the pass side. Take a look at the axles where the seals run, those are prone to wear and leak, but can be fixed with relocate bearings available. The pinion seal can be fixed with a thin repair sleeve that slides over the damaged area. Pull the rear cover and look for rust as well to make sure it didn't get damaged from rust. If you buy it right, this is about as good a deal on a rear axle swap as there is.
[Re: tobnHisglory]
#1605910
04/14/14 10:14 AM
04/14/14 10:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was working for Chrysler and they built it up for a lighter weight diesel... but that project was dropped
[Re: MoparBilly]
#1605913
04/14/14 07:01 PM
04/14/14 07:01 PM
sixpackgut
Charleston
Weight on the title says 3300 lbs. The van i'm buying is longer than that pink one. I will be bringing it home tomorrow
[Re: sixpackgut]
#1605916
06/17/14 12:27 AM
06/17/14 12:27 AM
sixpackgut
Charleston
[Re: sixpackgut]
#1605921
06/17/14 11:37 AM
06/17/14 11:37 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
That looks awesome Ray! See ya this afternoon.
