318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer
#1603818
04/06/14 06:38 AM
04/06/14 06:38 AM
Posts: 164 CH
plyrr69
CH
Hello
I am on the way to convert my 318 to a 413. for shure I have to change the Transmission to my car, but how about engine Mounts and so on, any sugestions?
thx in advance
D.
___________________________
.......plymouth tells it like it is...!
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer
[Re: plyrr69]
#1603819
04/06/14 10:04 AM
04/06/14 10:04 AM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
Should be easy,the 61 came with a BB..back in 1964 a friend pulled a 318 out of his 60,and put in a 413..from a New Yorker... damn thing was fast then..I Think he could use the same iron,t- flight but they had a different bellhousing for the BB..
[Re: stumpy]
#1603821
04/06/14 02:29 PM
04/06/14 02:29 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
IIRC The bells are removable from the iron trannys.Only thing is the early cranks are different.You cant mix and match them.You need a 62 up trans when they went to aluminum case.Then if 65 up you need a drive shaft with automatic.64 was the last year for B&T shaft for autos.65 last year for 4 speeds.If the 413 is pre 62 it will work.Rocky
Chrysler Firepower
[Re: plyrr69]
#1603822
04/06/14 07:30 PM
04/06/14 07:30 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
You need some 'Floating Power' big block engine mounts. They look like the poly mounts in there, but are different. You can get some aftermarket mounts at Imperial Services
1979 AMC Spirit, NHRA Q/SA
[Re: longram60]
#1603823
04/06/14 09:11 PM
04/06/14 09:11 PM
therocks
Niles , Ohio
Those mounts work well.My son has the prototypes in his 62 300.Been in for years.I also have them in my 65.Rocky
Chrysler Firepower
[Re: therocks]
#1603824
04/07/14 05:33 AM
04/07/14 05:33 AM
Posts: 164 CH
plyrr69
CH
Thx alot, so I can possibly use also the standard mounts. btw... how about swaybar? make sens so brint the car to more stabilisation, or not?
[Re: dogdays]
#1603826
04/08/14 10:57 AM
04/08/14 10:57 AM
Posts: 164 CH
plyrr69
CH
Hi, thx alot, i have already a 413 to put in the car... where should i get them? Firmfeel?
