318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer #1603818
04/06/14 06:38 AM
04/06/14 06:38 AM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
Hello
I am on the way to convert my 318 to a 413. for shure I have to change the Transmission to my car, but how about engine Mounts and so on, any sugestions?
thx in advance
D.
___________________________ .......plymouth tells it like it is...!
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: plyrr69] #1603819
04/06/14 10:04 AM
04/06/14 10:04 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Should be easy,the 61 came with a BB..back in 1964 a friend pulled a 318 out of his 60,and put in a 413..from a New Yorker... damn thing was fast then..I Think he could use the same iron,t- flight but they had a different bellhousing for the BB..
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: dynamite] #1603820
04/06/14 01:42 PM
04/06/14 01:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Isn't the emergency brake part of the trans on that body style? Although it won't be bad if the new trans has park which the original didn't.
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: stumpy] #1603821
04/06/14 02:29 PM
04/06/14 02:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC The bells are removable from the iron trannys.Only thing is the early cranks are different.You cant mix and match them.You need a 62 up trans when they went to aluminum case.Then if 65 up you need a drive shaft with automatic.64 was the last year for B&T shaft for autos.65 last year for 4 speeds.If the 413 is pre 62 it will work.Rocky
Chrysler Firepower
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: plyrr69] #1603822
04/06/14 07:30 PM
04/06/14 07:30 PM
Dunnellon, FL
longram60 Offline
longram60  Offline
Dunnellon, FL
You need some 'Floating Power' big block engine mounts. They look like the poly mounts in there, but are different. You can get some aftermarket mounts at Imperial Services
1979 AMC Spirit, NHRA Q/SA
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: longram60] #1603823
04/06/14 09:11 PM
04/06/14 09:11 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Those mounts work well.My son has the prototypes in his 62 300.Been in for years.I also have them in my 65.Rocky
Chrysler Firepower
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: therocks] #1603824
04/07/14 05:33 AM
04/07/14 05:33 AM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
Thx alot, so I can possibly use also the standard mounts. btw... how about swaybar? make sens so brint the car to more stabilisation, or not?
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: plyrr69] #1603825
04/07/14 01:19 PM
04/07/14 01:19 PM
dogdays Offline
dogdays  Offline
Switzerland, eh? Not so easy to find parts over there.
American cars from the '60s were boats, cornering was the farthest thing from their mind. So swaybars and some good gas shock absorbers would really help.
I'd suggest a 1 1/8" front bar, and a 3/4" rear bar as a safe place to start. On a rear wheel drive car the front bar always has to be stiffer than the rear bar.
You may consider stroking the Poly motor, it'll go more than 390 cubic inches with a 4" crank. People even make stroker kits for them.
R.
Re: 318 Poly to 413 Engine Swap in 1961 Dodge Dart Pioneer [Re: dogdays] #1603826
04/08/14 10:57 AM
04/08/14 10:57 AM
CH
P
plyrr69 Offline OP
plyrr69  Offline OP
P
CH
Hi, thx alot, i have already a 413 to put in the car... where should i get them? Firmfeel?
