Re: TBI to carb swap
[Re: dd340]
#1603506
04/05/14 04:56 PM
04/05/14 04:56 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
new intake, carb and electronic distributor. Not sure how it might play with the trans though, if an auto. Might need to install an OD and lockup kit. Similar to this http://www.transmissioncenter.net/SwapInformation.htm
[Re: Supercuda]
#1603507
04/05/14 05:12 PM
04/05/14 05:12 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
He already installed an a518 overdrive in it. I think I just need a toggle switch for the overdrive.
Is there some wiring I would need to do for the coil and distributor?
[Re: dd340]
#1603508
04/05/14 06:21 PM
04/05/14 06:21 PM
Supercuda
About to go away
About to go away
up yours
It would be the same as if you swapped a regular electronics ignition system in place of a points setup. An example http://www.fourforty.com/techstuff/ignition.html
[Re: Supercuda]
#1603509
04/05/14 08:09 PM
04/05/14 08:09 PM
RapidRobert
& a mechanical fuel pump and the earlier timing cover for that fuel pump & the Hughes engines' bolt on cam extension (it's cheap) so you'll have a lobe to actuate the pump lever
