E body Steering Column Rebuilt? #1602578
04/03/14 09:34 AM
04/03/14 09:34 AM
Australia
Aus70RT383 Offline OP
Australia
hi all,
im wanting to rebuild my steering column on my 1970 dodge challenger rt383 4 speed but have no idea where to start.sitting in my challenger and holding the steering wheel you can move the steering wheel back and forth but only so far. from the engine bay you can see the shaft sliding and it seems the only thing holding it to the steering box is the roll pin. i would like to replace everything from the steering box coupler to the steering wheel with all new parts clips bearings etc. can anyone provide a list of all parts required to rebuilt it and maybe pics from a manual?
best regards
jeremy
Re: E body Steering Column Rebuilt? [Re: Aus70RT383] #1602579
04/03/14 09:29 PM
04/03/14 09:29 PM
IN
ahy Offline
ahy  Offline
IN
Below is a link for moparmanuals.com. They can fix you up with the manual in CD form. Its really nice to have for lots of things. When I did my column I used a parts kit from Year One. I'm not sure they still offer it but worth checking.
I sent mine out for the work and regretted it. By the time I got it back and straightened out I could have done it myself.
http://www.moparmanuals.com/mopar/main/home.asp
Re: E body Steering Column Rebuilt? [Re: ahy] #1602580
04/03/14 10:29 PM
04/03/14 10:29 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Is there a way to remove the crush can off an E body column? I'm not that tall and have to scoot my seat up to reach my pedals. Doing so puts my wrists way past the wheels when my arms are semi-extended. Having a shorter column would be great for me
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: E body Steering Column Rebuilt? [Re: RylisPro] #1602581
04/03/14 10:50 PM
04/03/14 10:50 PM
Calgary, AB, Canada
73EStroker Offline
73EStroker  Offline
Calgary, AB, Canada
I doubt you could remove the crush can entirely but I believe either FMJ or A bodies came with a shorter crush can. You won't believe what taking a couple of inches off the length of the column would do for affect and feel. Also consider you will have to make the indicator lever more straight out from the column. Nothing is easy is it!
Re: E body Steering Column Rebuilt? [Re: RylisPro] #1602582
04/03/14 11:56 PM
04/03/14 11:56 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
off topic from the original post, but it would probably be simpler to use longer clutch/brake rods and move the gas pedal back a bit.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: E body Steering Column Rebuilt? [Re: RylisPro] #1602583
04/04/14 12:31 PM
04/04/14 12:31 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Rylis... yes the crush can can be removed... i did it on my challenger a long time ago... if i remember corectly, there's a big nut to be removed. As you know, I have a small steering wheel (11.5" diameter) and it has a deep dish ~5"... the smaller diameter wheel further makes the steering quicker, especially when running thru pylons and other quick manuevers. You might have to slightly bend the turn signal lever pending your final choice of steering wheel.
Re: E body Steering Column Rebuilt? [Re: RylisPro] #1602584
04/04/14 08:16 PM
04/04/14 08:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It has been 20+ years since I owned an E body, but I seem to recall that removing the can puts the wheel so close to the dash it'll catch your fingers at the top.
Don't be the exception.
Re: E body Steering Column Rebuilt? [Re: Supercuda] #1602585
04/04/14 08:39 PM
04/04/14 08:39 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
What about shortening an e-body can? Not too hard to do?
Re: E body Steering Column Rebuilt? [Re: brads70] #1602586
04/04/14 10:06 PM
04/04/14 10:06 PM
IN
ahy Offline
ahy  Offline
IN
Cut and weld is certainly possible... I wouldn't trust my welding skills on a part like that though.
Re: E body Steering Column Rebuilt? [Re: ahy] #1602587
04/04/14 11:20 PM
04/04/14 11:20 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Here's a good article on rebuilding the E-body column.
http://www.moparmusclemagazine.com/howto/mopp_0308_mopar_steering_column_rebuild/
I have a PDF of a more detailed breakdown if you need it.
Re: E body Steering Column Rebuilt? [Re: Devil] #1602588
04/05/14 11:44 PM
04/05/14 11:44 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
The can comes off just like any other steering wheel. It's splined like a wheel and has threads for puller bolts. But if you do remove it you'll need to replace it with a steering wheel that is splined the same as for cars w/o the spacer can. And that wheel may bee pretty far away. You'll need a wheel puller small enough to fit inside the can.
Re: E body Steering Column Rebuilt? [Re: Sixpak] #1602589
04/05/14 11:56 PM
04/05/14 11:56 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
From what I've read a B body smooth can is shorter and bolts right on, just have to find one
Sorry for going off topic
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: E body Steering Column Rebuilt? [Re: RylisPro] #1602590
04/06/14 11:24 AM
04/06/14 11:24 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Attached is some info I saved. Not sure who the original author was.
Re: E body Steering Column Rebuilt? [Re: larry4406] #1602591
05/07/14 11:05 PM
05/07/14 11:05 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Anyone know what diameter the steering shaft is?
is it 5/8" or 3/4"? How many splines does it have?
I have to modify my column to adapt a quick disconnect steering wheel and probably need to weld in a quick release hub
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
