exhaust manifold preference for Turbo? #160246
12/02/08 05:59 PM
12/02/08 05:59 PM
Tucson AZ
2
2cudabuck Offline OP
Tucson AZ
Any best exhaust manifold to use for my turbo setup for my 318 Cuda? If you guys have been following my Turbosonic build, it's a draw through. Love you guys longtime!!!
Buck
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: exhaust manifold preference for Turbo? [Re: 2cudabuck] #160247
12/02/08 06:09 PM
12/02/08 06:09 PM
WA 98043
thecarfarmer Offline
WA 98043
Whichever one'll fit easiest is probably best...
Ones from a heavy duty or HP 360-4V would probably be as good as anything, unless you score a (hard-to-find) set of manifolds from an early 340. Those may be slightly better.
The early '66 and down A-body manifolds don't breathe too well.
Not to hijack, but a lot of guys have been going away from draw-thru setups for a reason... but it ain't like you can't change to blow-thru if the car is a BEE-YATCH on cold starts, or has a laaaaaaaaaaaaaaaaag when you drop the hammer. You'll only have to bolt a carb back on the manifold and then change the plumbing from the compressor.
BTW, if you're set on going draw-thru, remember, it takes some special seals or bearings or something on the compressor side. I don't know if your turbo has the right stuff, but it's something to keep in mind.
-bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: exhaust manifold preference for Turbo? [Re: thecarfarmer] #160248
12/02/08 06:35 PM
12/02/08 06:35 PM
Tucson AZ
2
Tucson AZ
I was just wondering if truck manifolds dump out straighter and easier to loop than cars or something like that. I am aware of the draw through draw backs, (pun intended) but I got the whole system including turbo for next to nothing and aren't looking for a wheel stander, just something to offset the terrible HP loss here at altitude. plus, a cool factor when you pop the hood on cruise nights......
Re: exhaust manifold preference for Turbo? [Re: thecarfarmer] #160249
12/02/08 06:35 PM
12/02/08 06:35 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Seems shorty headers would be the best. Better flow, and weldable for flanges.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: exhaust manifold preference for Turbo? [Re: 70dart360] #160250
12/02/08 06:47 PM
12/02/08 06:47 PM
Tucson AZ
2
Tucson AZ
I was told to use manifolds so that more heat would be retained. (yes, that's what they said, I guess turbos like more heat!!)
Re: exhaust manifold preference for Turbo? [Re: 2cudabuck] #160251
12/02/08 08:19 PM
12/02/08 08:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The big problem w/SB manis can't be fliiped upside down. I think you'd be better of modifing a set on shorty headers, or making a set up yourself. If you use any production mani, you will have to run the exhaust back under the car and up to the turbo.
Re: exhaust manifold preference for Turbo? [Re: Mr.Yuck] #160252
12/27/08 06:06 PM
12/27/08 06:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You'd bet better off making your own manifolds for a turbo setup.
http://www.nicoclub.com/articles.php?id=216588
Don't be the exception.
