HELP with this Windsor 72 RR fender tag please! #1601113
03/31/14 01:08 PM
03/31/14 01:08 PM
NW/Indiana - Chi town
ricomondo Offline OP
This is the tag from a 72 RR I'm contemplating purchasing. The owner is a member here and gave permission for me to post with the edited VIN.
The reason for my post is I'm concerned as the top two lines (from the top) are crooked and the letters and numbers seem misaligned, and the trim tag screw hole cuts off part of the N in N96? But, the remainder of the tag seems ok.
Some background on the car: seller states he is the 2nd owner and that this is the original tag. Car has been restored.No build sheet to confirm the tag. I'll be posting the front and back of the tag. I'd like opinions please, as I haven't encountered this before.
GY3 71 Demon 340
Re: HELP with this Windsor 72 RR fender tag please! [Re: ricomondo] #1601114
03/31/14 02:34 PM
03/31/14 02:34 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
It appears to be a repop to me. The trim codes and vertical alignments appear to be good, but the line spacing and font alignment are terrible. Unfortunately I do not have enough Winsor built 72 runners around that time frame to tell if the VON makes sense or not.
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: HELP with this Windsor 72 RR fender tag please! [Re: Butterscotch71] #1601115
03/31/14 03:10 PM
03/31/14 03:10 PM
Thanks for the reply. Hopefully I'll get some more opinions so I can make an informed decision.
GY3 71 Demon 340
Re: HELP with this Windsor 72 RR fender tag please! [Re: ricomondo] #1601116
03/31/14 03:34 PM
03/31/14 03:34 PM
Oviedo, Florida
wanna72rr Offline
wanna72rr  Offline
Oviedo, Florida
That does not look like my 1972 RR Windsor built tag.
None of my numbers or letters are out of aligment.
The squence number is way different for a car built two months later.
My 2 cents is that is not original.
Re: HELP with this Windsor 72 RR fender tag please! [Re: wanna72rr] #1601117
03/31/14 03:43 PM
03/31/14 03:43 PM
Thank you!
Your font seems crisper, but I can see how fresh paint on the tag I posted could make the font seem less crisp.
GY3 71 Demon 340
Re: HELP with this Windsor 72 RR fender tag please! [Re: ricomondo] #1601118
03/31/14 04:28 PM
03/31/14 04:28 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Look at the similarities between the 2 tags, they are both crooked as heck. The "R11"s are both mis-aligned & if there was another line of codes on the red car - the LH screw hole would be thru the first code on the line.
Re: HELP with this Windsor 72 RR fender tag please! [Re: 6bblgt] #1601119
03/31/14 05:15 PM
03/31/14 05:15 PM
Now that u say that;
I do see the R11 and the END have similar stampings.
The first (1)in both R11's have a slight dip to them, and the ND in END in both pictured tags have a slight dip to them. Also, the 9 in N96 dips on both tags. I think that's a good sign. Thank u Dan
GY3 71 Demon 340
Re: HELP with this Windsor 72 RR fender tag please! [Re: wanna72rr] #1601120
03/31/14 06:08 PM
03/31/14 06:08 PM
Oviedo, Florida
wanna72rr Offline
wanna72rr  Offline
Oviedo, Florida
These numbers should be somewhat close shouldn't they? VON numbers
Also not one of all the pictures of Windsor plant tags I have for 72 have a code punched through with the screw hole.
My numbers are not as out of alignment as these or on any of the examples I have.
Believe me or not but in my opinion this tag is a reproduction.
Re: HELP with this Windsor 72 RR fender tag please! [Re: wanna72rr] #1601121
03/31/14 06:12 PM
03/31/14 06:12 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Vehicle Order Numbers originate at Chrysler or the ordering dealer, they are all over the ballpark.
& another '72 Windsor tag that would've had screw hole issues if the car had more equipment/OPTIONS.
Re: HELP with this Windsor 72 RR fender tag please! [Re: 6bblgt] #1601122
03/31/14 07:08 PM
03/31/14 07:08 PM
I sincerely appreciate your input everyone, and Dan thank you for going out of your way to upload the pictures.
GY3 71 Demon 340
Re: HELP with this Windsor 72 RR fender tag please! [Re: ricomondo] #1601123
03/31/14 09:35 PM
03/31/14 09:35 PM
Oviedo, Florida
wanna72rr Offline
wanna72rr  Offline
Oviedo, Florida
I understand we are all here to help each other out and free advice is worth exactly what you paid for it.
I have lots of examples of tags full to the top line with codes from the Windsor plant.
NONE of mine have a hole/screw punch through a code.
Here are a few that are not (not would have).
For what it's worth.
Re: HELP with this Windsor 72 RR fender tag please! [Re: wanna72rr] #1601124
03/31/14 10:10 PM
03/31/14 10:10 PM
Hmm... That's very interesting!
I guess the plot thickens.
Thanks for posting.
GY3 71 Demon 340
Re: HELP with this Windsor 72 RR fender tag please! [Re: ricomondo] #1601125
03/31/14 10:46 PM
03/31/14 10:46 PM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
Any pics of the car when new from first owner?
Stand behind your word
Re: HELP with this Windsor 72 RR fender tag please! [Re: Dodge] #1601126
03/31/14 10:59 PM
03/31/14 10:59 PM
I asked the current owner, if there's any pics, so we'll see.
GY3 71 Demon 340
