Need help with 09 hemi miss #1600549
03/30/14 01:12 PM
03/30/14 01:12 PM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Light comes on and it scans cyl 7 misfire p0307.We have changed plugs moved coil pack from one cyl to another. We moved injector from 7 to another cyl. Yesterday we changed valve springs. When you get after it the light comes on, then sometimes it will miss at idle and sometimes not. It does have the tick. Not sure what direction to go now.
Re: Need help with 09 hemi miss [Re: rickb67] #1600550
03/30/14 09:11 PM
03/30/14 09:11 PM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
Just guessing re- diagnostics- maybe a compression test or cooling system pressure test for a bad head gasket.
How about an injector noid light to see if wire to the injector is bad?
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
Re: Need help with 09 hemi miss [Re: TMCCuda] #1600551
03/31/14 01:52 AM
03/31/14 01:52 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
We had 120 lbs of air pressure to the cyl and had no leaks anywhere. we did have a stethoscope on the injectors and they were all clicking. The light only turns on if you get on it hard.
Re: Need help with 09 hemi miss [Re: rickb67] #1600552
03/31/14 09:50 AM
03/31/14 09:50 AM
Guitar Jones Offline
I had one 5.7 in a Durango that had a very slight coolant leak into the cylinder. This engine had been apart previously at another dealership and it looked like they drug the head across the floor scarring the deck surface. You didn't mention it being apart previously but it could be something similar. Get a combustion gas detector kit that is used to detect combustion gasses in the cooling system.
Re: Need help with 09 hemi miss [Re: Guitar Jones] #1600553
04/01/14 02:05 AM
04/01/14 02:05 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
As far as we know nothing major has been done to this engine.
Re: Need help with 09 hemi miss [Re: rickb67] #1600554
04/02/14 03:44 AM
04/02/14 03:44 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Long shot but check the under hood fuse/relay block.They are open to the elements and corrosion is a problem.
Leave the gun.......take the Cannoli's....Mike
Re: Need help with 09 hemi miss [Re: mike s] #1600555
04/02/14 01:32 PM
04/02/14 01:32 PM
Tidewater, VA
TMCCuda Offline
TMCCuda  Offline
Tidewater, VA
09 is a VVT MDS motor correct? Upper rpm miss makes me think something with the timing/ valvetrain/ cam phasing.
Another thing could be the intake runner change from short to long or vice versa. I wonder if soot in the intake will cause a sticky spot? Lean or rich condition maybe.
I know nothing about the VVT system just spit-balling here.
Re: Need help with 09 hemi miss [Re: TMCCuda] #1600556
04/03/14 02:26 AM
04/03/14 02:26 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Thanks for the advice. Drove to Sioux falls last weekend and worked on it. Drove 350 miles home Sunday and that is all I could think about. Well this weekend son is bringing it to Rapid City and taking my car home.
Re: Need help with 09 hemi miss [Re: rickb67] #1600557
04/03/14 05:01 AM
04/03/14 05:01 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I'm leaning toward a VVT issue as well. I'm told that the cam timing is advanced at low rpms and retards as rpms increase. A rapid acceleration may result in a "lag" in the cam timing, resulting in an erratic signal from the cam positioning sensor. Why only cyl # 7 is affected, i'm not sure.
Re: Need help with 09 hemi miss [Re: Kern Dog] #1600558
04/03/14 10:05 AM
04/03/14 10:05 AM
I would think this is not the case as it only is affecting one cylinder. If it was something like the VVT it would affect other cylinders as well.
Now having said that this engine is an MDS engine correct? I don't know what cylinders the MDS kills but there are four separate solenoids in the valley that control it, there could be a solenoid or harness problem if #7 is indeed one of the cylinders it kills.
Re: Need help with 09 hemi miss [Re: Guitar Jones] #1600559
04/05/14 04:07 AM
04/05/14 04:07 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Now that makes sense. I have been thinking it almost has to be electrical problem. I will figure out how to test those solinoids.
Re: Need help with 09 hemi miss [Re: rickb67] #1600560
04/05/14 09:43 AM
04/05/14 09:43 AM
I'm thinking a solenoid might be weak and under higher pressure it's leaking down.
Re: Need help with 09 hemi miss [Re: Guitar Jones] #1600561
04/08/14 01:37 AM
04/08/14 01:37 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Okay lifter wore the cam out. I still can't believe i didn't know what was going on. anyone know if dodge will pay something on this.
Re: Need help with 09 hemi miss [Re: rickb67] #1600562
04/08/14 09:45 AM
04/08/14 09:45 AM
Canada
WO23Coronet Online content
WO23Coronet  Online Content
Canada
The lifter wore the cam out? Did the roller on the lifter seize? I've never heard of that one before. Sounds like a good excuse to put a cam out of a 6.4 SRT in
Re: Need help with 09 hemi miss [Re: WO23Coronet] #1600563
04/09/14 02:59 AM
04/09/14 02:59 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
the lifter turned sideways and wore the cam out.
Re: Need help with 09 hemi miss [Re: rickb67] #1600564
04/09/14 11:00 AM
04/09/14 11:00 AM
How did that happen? Either way unless you are the original owner and it's still under a powertrain warranty I doubt Chrysler will help but you would have to run it by the service manager at your dealer and see if the district rep may help.
Let me caution you though that if you are not a good customer at that dealership they may not be inclined to do anything. But keep in mind the magic word, please. It can't hurt to ask. Good luck.
