What model differential was used in 1977 Dodge d 150's #1598458
03/25/14 11:18 PM
03/25/14 11:18 PM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
See title
Re: What model differential was used in 1977 Dodge d 150's [Re: 696pack] #1598459
03/25/14 11:40 PM
03/25/14 11:40 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
9 1/4
Re: What model differential was used in 1977 Dodge d 150's [Re: 696pack] #1598460
03/26/14 12:06 AM
03/26/14 12:06 AM
N
NITROUSN Offline
NITROUSN  Offline
N
8 1/4 = 10 bolts or 9 1/4 = 12 bolts.
Re: What model differential was used in 1977 Dodge d 150's [Re: NITROUSN] #1598461
03/26/14 12:25 PM
03/26/14 12:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Re: What model differential was used in 1977 Dodge d 150's [Re: 76dodgeboy] #1598462
03/26/14 05:08 PM
03/26/14 05:08 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Mine had the Chrysler 8 3/8 and it was a D150, not a 100 as my signature states. The 9 1/4 was also available.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: What model differential was used in 1977 Dodge d 150's [Re: Soopernaut] #1598463
03/26/14 05:18 PM
03/26/14 05:18 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
1/2 ton small block auto trucks usually got the 8 3/8, standard trans would get the 9 1/4. I suspect all big block trucks got the 9 1/4 but really don't know.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: What model differential was used in 1977 Dodge d 150's [Re: 3hundred] #1598464
03/26/14 06:18 PM
03/26/14 06:18 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
8.25 8 3/8 Same rear
Re: What model differential was used in 1977 Dodge d 150's [Re: 76dodgeboy] #1598465
03/26/14 06:48 PM
03/26/14 06:48 PM
foristell mo
serano Offline
serano  Offline
foristell mo
8.25-8.75-9.25 have seen all three in 72-80
Re: What model differential was used in 1977 Dodge d 150's [Re: serano] #1598466
03/26/14 07:55 PM
03/26/14 07:55 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I think the last year of the 8.75 was 74, after that it was the 9 1/4
Re: What model differential was used in 1977 Dodge d 150's [Re: CTD5.9] #1598467
03/26/14 11:57 PM
03/26/14 11:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
W100 were all 8.75 till 74. At least Early 74. I've come across a couple guys that claim there's is a 74 but Full-time 4wd So I assume they swapped mid late 74 in w series. but D100 73 had 8.75 and 8.25-8 3/8 possibly 9.25. My 73 Clubcab was a 8.25 if I remember correct. Not a 8.75
Re: What model differential was used in 1977 Dodge d 150's [Re: 76dodgeboy] #1598468
03/27/14 02:04 AM
03/27/14 02:04 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
After 74/75 model changeover, the two choices for a 1/2 ton were an 8 1/4 or a 9 1/4. There wasn't much rhyme or reason for which one ended up in which truck. I've seen a fair share of what was suppose to be heavy duty trucks with the 8 1/4, and light duty trucks sporting a 9 1/4. I suspect a great deal of them depended on what was checked on the order form, or what happened to be around at the assembly line. Gene
Re: What model differential was used in 1977 Dodge [Re: poorboy] #1598469
04/01/14 12:00 AM
04/01/14 12:00 AM
AZ.
696pack Offline OP
696pack  Offline OP
AZ.
Sorry, been gone for a while. I meant to ask about the FRONT diff (4X4)
Re: What model differential was used in 1977 Dodge [Re: 696pack] #1598470
04/01/14 01:55 AM
04/01/14 01:55 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
D100/150s didnt have front differentials..
W 100/150s had Dana 44s
I am truckless..
Re: What model differential was used in 1977 Dodge [Re: 340SHORTY] #1598471
04/01/14 02:25 PM
04/01/14 02:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
And Only D44s
