Re: Reverse flow coolant, pro/cons?
[Re: EchoSixMike]
#1598171
03/25/14 11:29 AM
03/25/14 11:29 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have run a reverse flow adapter and Chev style electric pump for many years, no problems. I run 440-1 heads, make about 880 hp on Methanol. I don't see any down side at all, just potential power gains (more so on gas?)
[Re: EchoSixMike]
#1598172
03/25/14 11:42 AM
03/25/14 11:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Being that you will keep the heads cooler you would have less of a chance to detonate.. but with E-85 you reduce that also... so with both of those I would think you can bump up the timing... on my E-85 set up I only increased the timing 1 degree over the gas but I run a standard flow cooling system on my SB
[Re: wyldebill]
#1598177
03/26/14 02:10 AM
03/26/14 02:10 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i am planning on doing this on my 512. i was told that i need to install air bleeds in the heads to reduce air pockets or hot spots. anybody know anything abiut that?
i use the Mezzarie reverse flow pump. when filling with coolant on an empty block it's no problem. the pump moves the air out pretty quick & everything works great. BUT if you drain the block for any reason & refill a partially fill block you get a b@st@rd issue with a big airlock that the pump will not pick up the water. to fix this problem i've found raising the back of the car & then the pump seems to pick up & it's all good again. it's only an issue when the block is still partially full of water & you refill the radiator. once you know how to get over it, life is sweet again & the pump works great.
[Re: rebel]
#1598178
03/26/14 12:28 PM
03/26/14 12:28 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
There is a simple fix for this. Run a small line from the top of the pump cavity to a higher spot on the radiator tank. This way the air cavitating in the pump can get out. This can be done for any problem area.
[Re: go green]
#1598181
04/01/14 01:20 AM
04/01/14 01:20 AM
MR_P_BODY
There is not one OEM car on the planet that goes backwards in the coolant design . I would think that the $100,000,000,000 auto industry knows what they are doing . Cooling during the run is minimal and the reverse cooling is a monkey see monkey do thing . Do you guys think the law of physics change for Meziere and Indy making air not rise to top of the cooling system ? Its sounds reasonable in short be its just a trick of the week . Its just a waist of time .
Thats always been my thought... the auto companies spend 100s of thousands on testing... I never changed over because I think they got it right in the testing and like you said... this is ONLY a 1/4 mile... I dont know what the pro stocks use but they are the badest out there for a N/A engine
[Re: MR_P_BODY]
#1598182
04/01/14 12:39 PM
04/01/14 12:39 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I`ve ran this Indy/Meziere system in high heat / humidity conditions and have had ZERO problems . Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: AndyF]
#1598184
04/01/14 02:28 PM
04/01/14 02:28 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
I talked to an engine builder who was able to run pump gas in a 13:1 compression sbc by reverse cooling and pumping water into 5 locations on each head to eliminate any hot spots or steam pockets. I found it very interesting...
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: go green]
#1598185
04/01/14 03:21 PM
04/01/14 03:21 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
Isn't the LS chevy motor reverse flow ???
We ran the enginemaster engine reverse flow , 12.2 compression with alum heads on 91 octane , made over 700HP on Pierce's dyno in Lansing the day before the competition????
As stated getting the air out of the heads without bleeds is a beotch and can lead to overheating the top end because of air pockets ... been there, had a $10k paperweight to show for it ...
