Page 2 of 4 1 2 3 4
Re: 60 FT TIMES [Re: dragram440] #1597747
03/24/14 06:15 PM
03/24/14 06:15 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
That just seems horrible for that combo. One good thing is there is definately room for improvement! That is a really tall tire for that gear and e.t. I have cheapo shocks and stock leafs and I run 1.48 to 1.49 60'. My guess is a lot of its your converter. I run a coan 8" and it is suprisingly tight on the street and flashes aroud 5000-5200.
how is your in gear idle for street use?
Re: 60 FT TIMES [Re: GTX MATT] #1597748
03/24/14 06:18 PM
03/24/14 06:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Raising the ft. isn`t the answer...........get the rear lower by getting the c-vert -1 lower rears and a 2" lowering block the get the pinion in the 4-5 nose down range and THEN see what happens.
Re: 60 FT TIMES [Re: GTX MATT] #1597749
03/24/14 06:25 PM
03/24/14 06:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It sure can... the front has to move farther to
get the weight to transfer to the rear...
Mr P, not being a wise azz, but what if his front were higher/the car was more level, assuming he still had good front suspension travel?
You dont want to raise the front you want to lower
the rear... by raising the front you just lessen the
amount of travel... you would like around 5" of travel
Re: 60 FT TIMES [Re: MR_P_BODY] #1597750
03/24/14 06:35 PM
03/24/14 06:35 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
"You dont want to raise the front you want to lower
amount of travel... you would like around 5" of travel"
looking at the pix in the sig line the front end looks like a decent height. back has to come down.
Re: 60 FT TIMES [Re: Mr.Yuck] #1597751
03/24/14 06:46 PM
03/24/14 06:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
didn't read all the post but the first thing I see is the wrong converter if you are looking for 60' put a real converter in that thing and if you can make it hook you will see the 60' improve a ton.
Re: 60 FT TIMES [Re: draginmopars] #1597752
03/24/14 06:47 PM
03/24/14 06:47 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
1.527 @ 7.353
Nice! I was pretty happy with my 1.71 @ 7.89 but you've got me beat big time.
Re: 60 FT TIMES [Re: dustergirl340] #1597753
03/24/14 07:07 PM
03/24/14 07:07 PM
smyrna,tn
draginmopars Offline
smyrna,tn
dustergirl340-thanks
we're trying and learning
bonefish says he wants to go to a narrower tire to lower the rear
dragram440 - says
we run the same ET street tire as bonefish
at the time it was a 4.56 until this,
then went to the 4.10 cause the gear is what we had
what would be a better size tire to run ?
1/8 mile only
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: 60 FT TIMES [Re: draginmopars] #1597754
03/24/14 07:17 PM
03/24/14 07:17 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
The MP Chassis book says to measure from the back of your rocker to the ground, then measure from the front of the rocker to the ground and that the front of the rocker should be one inch shorter.
I don't know if this applies to cars with Cal Tracs too.
I'm at a 1.68 60 foot and 7.86 1/8. I think that's a pretty good 60 foot for what my car is and the times it runs
Re: 60 FT TIMES [Re: Quicktree] #1597755
03/24/14 07:20 PM
03/24/14 07:20 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I agree with this
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 60 FT TIMES [Re: Quicktree] #1597756
03/24/14 07:31 PM
03/24/14 07:31 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
thats what im thinkin.the vert company i delt with talked me into tradin my 8 inch 5000 stall vert for a 9 inch 3500.they told me i would have the best of both worlds,good trak performance and good street manners.changing the wheels tires and springs aint gunna happen at this time(but will eventually).im gunna go to the trak this sunday mabey i can get somone to take some vidio.i know the rear needs some work but its hard the beleive it has this much efect.
Re: 60 FT TIMES [Re: 67Satty] #1597757
03/24/14 07:32 PM
03/24/14 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What was that measurement for... a old pro stock..
forget that measurement.. a lot if the info is good
in that book but some is OLD and out dated... it is
easier to transfer weight if it if closer to the
CG height... thats why a engine is raised in some cars
Re: 60 FT TIMES [Re: bonefish] #1597758
03/24/14 07:40 PM
03/24/14 07:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it' makes a huge difference, find a new company. I would have a 8" 5600 street or not
Re: 60 FT TIMES [Re: bonefish] #1597759
03/24/14 07:42 PM
03/24/14 07:42 PM
Daisyland USA
jnkgal Offline
jnkgal  Offline
Daisyland USA
Bonefish- I notice your location s.w.fl
What track would that be
We enjoy going to Bradenton
plans are to take the Dart and Rampage
down there
when the car hauler is finished>paint
tracks still closed for winter here
i love bradenton its a great trak but i usually go to immokalee its only about 30 minutes from my house.
Bradenton is well organized more than the other tracks we have been to.
Immokalee as I estimated maybe almost 2 hours from Bradenton? maybe another one we need to visit.
That is the area Id love to live. Maybe one day we can just move down there. awesome weather ( except hurricanes) Great weather, and the race season is longer.
"A goal without a plan is just a wish."
Re: 60 FT TIMES [Re: bonefish] #1597760
03/24/14 07:48 PM
03/24/14 07:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Then why ask about the back end of the car... I dont
like telling people where to spend money... thats
why I try to answer the questions that are asked
with a explanation of why or what will change
Re: 60 FT TIMES [Re: jnkgal] #1597761
03/24/14 07:59 PM
03/24/14 07:59 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If it's not spinning the tires all the chassis work in the world isn't going to do much. I would concentrate on why it's down on power. Does it bog? 4.10 with 30" tire isn't helping. If the gear is what you have, try to borrow a shorter set of tires. What intake? What size PTC is it, 9"? 3800 flash seems pretty low with that many cubes. Where is the timing? I don't agree that 99 mph is 10.70, That's optimal. My street car runs 7.0@100 with low 1.50 60 ft. Most bracket cars I see might go 6.90 at that speed. The basic parts are all there.Right now it looks like it's making about 600HP. That combo should be good for more HP.
Doug
Re: 60 FT TIMES [Re: MR_P_BODY] #1597762
03/24/14 08:34 PM
03/24/14 08:34 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i appriciate your input and you answered my question but other responsese also made me aware that i have other problems not JUST my rear susp.i have another vert i do not have another rear suspention so although you have made me aware that it IS a problem i will have to address other areas first and live with the wheels for now.
Re: 60 FT TIMES [Re: dvw] #1597763
03/24/14 08:51 PM
03/24/14 08:51 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If it's not spinning the tires all the chassis work in the world isn't going to do much. I would concentrate on why it's down on power. Does it bog? 4.10 with 30" tire isn't helping. If the gear is what you have, try to borrow a shorter set of tires. What intake? What size PTC is it, 9"? 3800 flash seems pretty low with that many cubes. Where is the timing? I don't agree that 99 mph is 10.70, That's optimal. My street car runs [Email]7.0@100[/Email] with low 1.50 60 ft. Most bracket cars I see might go 6.90 at that speed. The basic parts are all there.Right now it looks like it's making about 600HP. That combo should be good for more HP.
Doug
I agree, if its not spinning the tires all the chassis work in the world wont work.
Also the 99 mph 1/8th would be a optimal setup for a 10.70 in the 1/4.
If you take into account the slow 60 ft and it still was able to hit 99 mph 1/8th, whats it going to run when it does 60 ft./ not bog off the line. Typically a car running around 100 mph 1/8th will pick up around 24 mph or so on the back half. Thats around a 10.75 optimal, add in the bad 60 ft. aspects and this car is a sub 10.70 car potential in the 1/4 when it gets online.
That vert is flashing to low for that 520 combo. This car has some kind of tune issue coming off the line IMO. But you cant rule out a vert problem either.
Re: 60 FT TIMES [Re: dvw] #1597764
03/24/14 08:55 PM
03/24/14 08:55 PM
Locomotion Offline
Locomotion  Offline
I don't have any specific answers or even specific suggestions, but one concern is the 520 cubic inches! A motor that big shouldn't need a lot of gear or converter. But that also looks like a lot of weight for that engine to move. Considering the narrow tires, it may be difficult to hook up IF you can figure out why it appears to be down on power. In other words, it may just blow through the tires if he engine is tuned to potential anyway. Big block (440, Hemi, 427, etc.) Stock Eliminator cars run low 10's and even high 9's on 9" tires and Cal-Tracs. But they have limited engine size, cam, heads, compression, etc. and a lot of time is spent on shocks, suspension adjustments and weight distribution. Track prep also has a lot to do with it. The more power you make, the more critical it is for everything to be "just right".
Gears will be easier to narrow down. If it hooks, you'll need a Dana 60. But converters can be tricky. I run converters advertised around 4,400. But they actually flash to 5,100-5,400 rpm on my 360! (Autometer playback tach.) Converter manufacturer need to have an idea of around where the torque peak is. Even then, similar advertised converters can vary a lot.
Re: 60 FT TIMES [Re: Sport440] #1597765
03/24/14 08:59 PM
03/24/14 08:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
I would think that its way down on power on the low
end to cause a low stall(well below the torque)...
I would/will ask if the cam was degreed in and what
is it at... the conv might be just a real low stall
for the engine... but before I trashed it I would
sure want to know more about the cam.... and with
a tall tire it only makes things worse if the cam
is retarted... it would take too much time to spin up
Re: 60 FT TIMES [Re: MR_P_BODY] #1597766
03/24/14 09:07 PM
03/24/14 09:07 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Doug
cam is installed at 106 as per the manufacturers recomendatiom.but it does rev kinda slow,it realy doesnt seem to come on till about 3000 or so.
Page 2 of 4 1 2 3 4
