Re: 60 FT TIMES
[Re: bonefish]
#1597728
03/24/14 01:06 PM
03/24/14 01:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
It sure can... the front has to move farther to get the weight to transfer to the rear... I cant say how much the difference would be.. but most any car will 60' better with a lower rear.. it comes to a point that if its too low the front end will be up in the air too long and may be reading the 60' with the rear tires
Re: 60 FT TIMES
[Re: Locomotion]
#1597730
03/24/14 01:52 PM
03/24/14 01:52 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
this combo is 520 ci.alum block.10.2 comp. indy 325 CNC heads prepped by PRH. comp cam [Email]263@50[/Email] in.,269@50 ex.GVL is649-654. 9 in. PTC vert that flashes at around 3800.410 dana,727 mvb.30x12.5 rear tires. 1050 dom.with TTI 2in. headers into 3 in ex. car weighs around 4000 w/me in it.with a 1.7147 60ft it went 99mph. 1/8 mi.i had people watch and they said the tires are not spinning.
Re: 60 FT TIMES
[Re: bonefish]
#1597732
03/24/14 02:40 PM
03/24/14 02:40 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Take some white shoe polish and put a 2 to 3 inch stripe on the tires, both of them, from the edge of the rims straight down to the outside edge of the tires and have someone video a run, do one for each side of the car . Look at those video in slow motion to see what the tires are really doing I can't tell if your rear tires are slicks, street tires, bias ply or radials What are they?
Re: 60 FT TIMES
[Re: bonefish]
#1597735
03/24/14 03:14 PM
03/24/14 03:14 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I just put my Cal-tracs on so I can't tell you how much better they are, but I'm in the same boat. Was cutting 1.65-1.75 sixty foot, my car was spinning, one guy told me the car was unloading. I went w/ the -1 monos and it still sits about 1/2" higher than the old XHD springs. I keep my front end low but I'm going to raise it 3/4" maybe more. You car seems to have a ton of rake to it. Can you bring the front up some? You might also want to consider 1" lowering blocks in the rear. Did you set the pre-load like the directions state? (bottom out and 1/4 turn) I noticed the butt end raises up as you crank the bars. FWIW my car runs around 11.40@120. I think my 1/8 is in the 7.30ish range. I'm shooting for 11.teens @ 120+.
Re: 60 FT TIMES
[Re: Mr.Yuck]
#1597737
03/24/14 03:52 PM
03/24/14 03:52 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
carb,50 cc pumps front and rear,35 squirters.jetted 89 square.no PV.tires are MT ET streets.the vert is a little soft but its a street mostly car.the launch doest feel as bad as it shows,i was shocked when i looked at the slip. ide really like to find a 30 in. tire about 9 inces wide and lower this thing down. PS.timming ,20 initial 38 all in by 1200
Re: 60 FT TIMES
[Re: draginmopars]
#1597738
03/24/14 03:54 PM
03/24/14 03:54 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
your combo is close to our 68 Satellite we were 1.631 @ 7.382
loosen up the front with 90/10 shocks
1.527 @ 7.353
540 /4500, 4.10 dana/31x14-15 super comp headers also running a 1050 Dominator
no major tuning yet only got 4 passes last year on E-85
got 90/10,s on the front.
Re: 60 FT TIMES
[Re: draginmopars]
#1597740
03/24/14 04:31 PM
03/24/14 04:31 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
Bonefish- I notice your location s.w.fl What track would that be We enjoy going to Bradenton plans are to take the Dart and Rampage down there when the car hauler is finished>paint tracks still closed for winter here
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
Re: 60 FT TIMES
[Re: draginmopars]
#1597742
03/24/14 04:50 PM
03/24/14 04:50 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i love bradenton its a great trak but i usually go to immokalee its only about 30 minutes from my house.
Re: 60 FT TIMES
[Re: Mr.Yuck]
#1597745
03/24/14 06:07 PM
03/24/14 06:07 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
That just seems horrible for that combo. One good thing is there is definately room for improvement! That is a really tall tire for that gear and e.t. I have cheapo shocks and stock leafs and I run 1.48 to 1.49 60'. My guess is a lot of its your converter. I run a coan 8" and it is suprisingly tight on the street and flashes aroud 5000-5200.
67' charger 499 RB
10.57 at 127
