Re: How do you recalibrate a gas gauge in a 1966 coronet
[Re: fastcoronet]
#1595534
03/19/14 09:45 PM
03/19/14 09:45 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
do you mean when you lift the arm ALL the way up, the gauge only goes to the 3/4 position?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: fastcoronet]
#1595536
03/19/14 09:49 PM
03/19/14 09:49 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
That's the problem with the new ones they make... plenty of threads about them and a thread about having good ones made also. I stick with originals whenever possible, been there with the new cheaper ones and not worth the hassle.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: amxautox]
#1595537
03/19/14 10:13 PM
03/19/14 10:13 PM
Posts: 72 rising sun, maryland
fastcoronet
yes that is what I am saying regarding the 3/4 tank showing on my gauge. I replaced the tank with a cell and install a new aftermarket 73-10 sending unit. also had the same problem when I had the original sending unit. I replaced the original sending unit with a aftermarket and had the same readings. I have had three different sending units and all 3 read the same.
[Re: fastcoronet]
#1595538
03/19/14 10:21 PM
03/19/14 10:21 PM
amxautox
then your gauge is off, bad. check the gauge's ground.
What would be good to do is check all those sending units with a known good gauge.
Tom
author unknown
