WIDE OPEN VACUUM TEST...................... #1595247
03/19/14 01:50 AM
03/19/14 01:50 AM
State of confusion
Thumperdart Offline OP
State of confusion
How many of you folks have done a dyno or street wide open test to see how much vacuum you have? After much thinking and research I`m thinking my 3.5 p/v COULD be closing at wot if I`m pullin more that a few inches of vacuum............Anyone?
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595248
03/19/14 02:35 AM
03/19/14 02:35 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I run a TQuad on my stocker. At WOT I have zero vacuum.
Raul
Re: WIDE OPEN VACUUM TEST...................... [Re: Aspen7695] #1595249
03/19/14 03:20 AM
03/19/14 03:20 AM
State of confusion
State of confusion
Raul
Is that wot in high gear wooded?
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595250
03/19/14 04:00 AM
03/19/14 04:00 AM
Put a vacume gauge in the car where you can see it easily and go for a ride Probally not going to see any vacume with yoour parts, 1050 Dominator and so on What does the wide ban say
Re: WIDE OPEN VACUUM TEST...................... [Re: Cab_Burge] #1595251
03/19/14 10:43 AM
03/19/14 10:43 AM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
with my 408 and a 950 I have 1.5-2"@wot. that's why I decided to try a dominator this year.
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595252
03/19/14 11:50 AM
03/19/14 11:50 AM
Az
Crizila Offline
Crizila  Offline
Az
Any vacuum basically sez restriction. I know some who do carb sizing that way. Through the lights, you wanna see no more than 1.5" for a race only application.
Fastest 300
Re: WIDE OPEN VACUUM TEST...................... [Re: Crizila] #1595253
03/19/14 11:59 AM
03/19/14 11:59 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595254
03/19/14 12:06 PM
03/19/14 12:06 PM
gregsdart Offline
gregsdart  Offline
At 7,000 rpm and 100 percent VE, you pull 950 cfm with 470 cubes. Your VE may be over that, but not by much. I would think the pv would be plenty high, and your WOT vacuum will be 1.6 or less. Probably the only real test would be a AFR test to see what is going on. You could also put a new 4.5 in it and test it.
Re: WIDE OPEN VACUUM TEST...................... [Re: gregsdart] #1595255
03/19/14 01:35 PM
03/19/14 01:35 PM
State of confusion
State of confusion
Will install a vac gauge soon and test these things but I can`t get my wot rich enuff w/out jetting it to the moon so was just curious. I`ll get some 26 hsb`s also and go from there. Right now I`m bet. 12.8-13.2 at wot and VP likes to see low 12`s w/their now 101 unleaded.
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595256
03/19/14 01:53 PM
03/19/14 01:53 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
Try sticking a plug in it and jetting up till your fat enough and record the jet number. Figure out the difference flow of your current primary jets and what its jets it took without the pv. That's how much your power valve channels need to flow.
Re: WIDE OPEN VACUUM TEST...................... [Re: Baxter61] #1595257
03/19/14 01:57 PM
03/19/14 01:57 PM
State of confusion
State of confusion
I tried that years ago before the wide band and just may again it`s just a pain testing on the street at 120+ mph............
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595258
03/19/14 01:59 PM
03/19/14 01:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if your pulling over 3.5" of vacuum at WOT you've got issues. 3.5" would indicate a very big restriction on the intake/carb. i'd look for fuel delivery problems.
Re: WIDE OPEN VACUUM TEST...................... [Re: lewtot184] #1595259
03/19/14 02:15 PM
03/19/14 02:15 PM
State of confusion
State of confusion
I personally don`t see it pullin that much and it was a suggestion to check it out but I leave no stone unturned and will VERIFY everything before I hit the track here soon...........
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595260
03/19/14 02:53 PM
03/19/14 02:53 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
need a co-pilot?
Re: WIDE OPEN VACUUM TEST...................... [Re: Baxter61] #1595261
03/19/14 03:23 PM
03/19/14 03:23 PM
State of confusion
State of confusion
need a co-pilot?
Come on.............
Re: WIDE OPEN VACUUM TEST...................... [Re: Thumperdart] #1595262
03/23/14 10:42 AM
03/23/14 10:42 AM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
Sorry it took so long to reply. I was racing at Las Vegas.. I have zero vacuum at WOT all the way down the track.
Raul
Re: WIDE OPEN VACUUM TEST...................... [Re: Aspen7695] #1595263
03/23/14 10:48 PM
03/23/14 10:48 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I never use a PV lower than 6.5 except in the borrowed carb i used for drag week last year and i believe that was happening to me but it was actually helping.
There is no reason to have a 3.5 PV in a carb. Do not listen to anyone that tells you to use a PV that is 2" lower. That is complete nonsense
