Re: WIDE OPEN VACUUM TEST......................
[Re: Thumperdart]
#1595254
03/19/14 12:06 PM
03/19/14 12:06 PM
Posts: 10,023 Frostbitefalls MN (Rocky&Bullw...
gregsdart
At 7,000 rpm and 100 percent VE, you pull 950 cfm with 470 cubes. Your VE may be over that, but not by much. I would think the pv would be plenty high, and your WOT vacuum will be 1.6 or less. Probably the only real test would be a AFR test to see what is going on. You could also put a new 4.5 in it and test it.
[Re: Thumperdart]
#1595258
03/19/14 01:59 PM
03/19/14 01:59 PM
Posts: 3,916 usa
lewtot184
usa
How many of you folks have done a dyno or street wide open test to see how much vacuum you have? After much thinking and research I`m thinking my 3.5 p/v COULD be closing at wot if I`m pullin more that a few inches of vacuum............Anyone?
if your pulling over 3.5" of vacuum at WOT you've got issues. 3.5" would indicate a very big restriction on the intake/carb. i'd look for fuel delivery problems.
[Re: Thumperdart]
#1595260
03/19/14 02:53 PM
03/19/14 02:53 PM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
I tried that years ago before the wide band and just may again it`s just a pain testing on the street at 120+ mph............
need a co-pilot? ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: Aspen7695]
#1595263
03/23/14 10:48 PM
03/23/14 10:48 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I never use a PV lower than 6.5 except in the borrowed carb i used for drag week last year and i believe that was happening to me but it was actually helping.
There is no reason to have a 3.5 PV in a carb. Do not listen to anyone that tells you to use a PV that is 2" lower. That is complete nonsense
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
