Leaf Spring part numbers #159508
12/01/08 05:36 AM
12/01/08 05:36 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Just got my leaf springs out for some detailing.
I've noticed the springs have different part numbers.
Does this mean they are left and right handed or has one just been changed at some time??
Keeping the Bee Buzzin'
Re: Leaf Spring part numbers [Re: Simonic] #159509
12/01/08 05:38 AM
12/01/08 05:38 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
And this is the other one
Re: Leaf Spring part numbers [Re: Simonic] #159510
12/01/08 09:35 AM
12/01/08 09:35 AM
None
71rm23 Offline
71rm23  Offline
None
Yes. Different P/N's for the left and right. Make sure they go back in the same position.
Re: Leaf Spring part numbers [Re: 71rm23] #159511
12/02/08 06:32 AM
12/02/08 06:32 AM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
Ok.
Which side is which please?
I can remember where they came from but a previous 'careful' owner may have had them out and put them back wrong
Re: Leaf Spring part numbers [Re: Simonic] #159512
12/02/08 02:46 PM
12/02/08 02:46 PM
None
71rm23 Offline
71rm23  Offline
None
Ok.
If I remember right, I think odd number goes on the right and vise versa. Hope someone else chimes in with the right answer for ya.
Re: Leaf Spring part numbers [Re: Simonic] #159513
12/02/08 03:19 PM
12/02/08 03:19 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
0928 = 92nd day of 1968 - 1 Apr 1968
0858 = 85th day of 1968 - 25 Mar 1968
The part number should be stamped on the same leaf in a different location and should be 7 digits.
Example:
3004 767 = Left spring
3004 768 = Right spring
Re: Leaf Spring part numbers [Re: Snoopy] #159514
12/05/08 07:55 PM
12/05/08 07:55 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
I do have another number stamped on the same leaf at the curved end.
It's the same on both of 'em
2539212
does this mean i've got 2 springs from the same side??
Re: Leaf Spring part numbers [Re: Simonic] #159515
12/05/08 08:16 PM
12/05/08 08:16 PM
Snoopy Offline
Snoopy  Offline
The 440 & Hemi came with two different springs - see example above. They may have been an option with other engines. Others used the same spring on both sides.
2539212 - If you have your broadcast sheet, look under Build Codes for "212" under the rear spring column.
Re: Leaf Spring part numbers [Re: Snoopy] #159516
12/05/08 11:06 PM
12/05/08 11:06 PM
united kingdom
Simonic Offline OP
Simonic  Offline OP
united kingdom
i don't have a build sheet,however the info you've given me is excellent.....just what this forum is all about
many thanks
Re: Leaf Spring part numbers [Re: Simonic] #159517
12/05/08 11:56 PM
12/05/08 11:56 PM
Snoopy Offline
Snoopy  Offline
This is from a 69 383 B-Body broadcast sheet.
