Lost reverse in a 2004 Dakota V6 automatic #1590729
03/09/14 11:33 PM
03/09/14 11:33 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Grandson was stuck and rocking truck back and forth, and lost reverse. Forward gears ok but nothing in reverse. Fluid is a little dirty, but doesn't smell burn't. Truck only has about 60,000 on the clock. Any ideas???
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: farmboy] #1590730
03/09/14 11:38 PM
03/09/14 11:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Possible broken band.
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: stumpy] #1590731
03/09/14 11:53 PM
03/09/14 11:53 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Fairly common to break the low/reverse band and then you have no reverse. I have replaced a couple of them, unfortunately you have to take the transmission out and almost completely apart to replace it. Sorry, it could be worse.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: Polarapete] #1590732
03/10/14 02:15 AM
03/10/14 02:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Try the truck in manual low gear and see if it has engine braking. If it does not then the low/reverse band is not applying. Ron
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: farmboy] #1590733
03/10/14 02:47 AM
03/10/14 02:47 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The ear came off the band. Pretty common.
Bring it and the one from your Challenger by the house and I'll do a package deal.
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: GY3] #1590734
03/10/14 12:35 PM
03/10/14 12:35 PM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
Mark, I would love to do that, but daughter already farmed it out to a local shop, and my guess is, they are going to get ripped. Nobody wanted to listen to Grandpa. On the other hand, you serious about doing the 727?
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: farmboy] #1590735
03/10/14 10:07 PM
03/10/14 10:07 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
That's a shame. A $15 band and some fluid and we could've had him back on the road.
Absolutely, bring it by. Gotta get it done for Mo-Kan, right?!
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: GY3] #1590736
03/11/14 12:06 AM
03/11/14 12:06 AM
kansas
farmboy Offline OP
farmboy  Offline OP
kansas
I moved some cars around today, and got the lift open, might get enthused and drop the tranny this week. Thanks
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: farmboy] #1590737
03/11/14 12:43 AM
03/11/14 12:43 AM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
2004 Dakota tranny does not use a reverse band. It has clutches and they are probably torched.
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: farmboy] #1590738
03/11/14 12:50 AM
03/11/14 12:50 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
An 04 Dak with a 3.7 will have a 42RLE trans. They DO NOT have any bands to break.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: 71yelladustr] #1590739
03/11/14 02:19 AM
03/11/14 02:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
From what I remember even if it is a 3.7 I was pretty sure it had the option of a 42RE also behind it. But I dont even remeber what year the 3.7 came out as I would have to look it up. Ron
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: 383man] #1590740
03/11/14 05:14 PM
03/11/14 05:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's a 42RLE, no bands.
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: John_Kunkel] #1590741
03/12/14 12:41 AM
03/12/14 12:41 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Isn't a 42RLE basically a "truck" 604??? In that case, there's a clutch gone.
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: John_Kunkel] #1590742
03/12/14 01:31 AM
03/12/14 01:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree if it is a 42RLE no bands but what I was saying was I thought I remember the 42RE also being avalible behind some 3.7's. But it may have only been in the car model as I dont remember for sure what models it was. Unless the 2004 Dakota only had the 42RLE behind the 3.7 then my memory is off. Ron
Re: Lost reverse in a 2004 Dakota V6 automatic [Re: superwrench] #1590743
03/12/14 01:34 AM
03/12/14 01:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Basically your right just 5 clutches as I would say its like a rear wheel drive version of the 604. Ron
