1968-70 Charger dash frame differance. #1590254
03/09/14 02:37 AM
03/09/14 02:37 AM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
What is the differance between the 68 to 70 Charger Rallye dash frames besides the ignition switch? I have a 1968 Charger and the dash frame is rusted out along the windshield. I can get a dash frame from a 1970 Charger that has no rust. I know that the 70 has no hole in the frame for the ignition switch but can I just add the hole and bracket to the 70 dash for the ignition switch and then transfer everything from my 68 dash frame to the 70 dash frame?
Re: 1968-70 Charger dash frame differance. [Re: LTLBEE] #1590255
03/09/14 11:53 AM
03/09/14 11:53 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
They are all different. 68 Used a different dash pad. It's thin and sticks out more. 69 used a bigger shorter pad and the 70 had the key in the column. I think an ac dash is different as well.
Re: 1968-70 Charger dash frame differance. [Re: fastmark] #1590256
03/09/14 03:44 PM
03/09/14 03:44 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Agreed.....look for a dash out of a 68 Charger or Super Bee. If you change to a 70 there are many differences from the 68 including: all lower pad mounting, glove box door mounting, ignition switch location, upper dash pad etc.
Only way I would go to a 70 would be if you can get a complete assembly to bolt in.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1968-70 Charger dash frame differance. [Re: 70gtx440dana] #1590257
03/09/14 06:01 PM
03/09/14 06:01 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
What I done done before if the upper steel part is rusted out were it bolts to the inside of the cowl, I have taken any 68-70 dash and cut the spot welds -were the top of the dash and the underside of the dash is spot welded together and a few spot welds on along the sides and a couple were the defroster ducts are and separate the top from the bottom,/underside is...and just replace the top, they are all the same. I have done this for customers a few times.
Re: 1968-70 Charger dash frame differance. [Re: GLR] #1590258
03/09/14 08:02 PM
03/09/14 08:02 PM
NY
LTLBEE Offline OP
LTLBEE  Offline OP
NY
This is what I will do since I already have a regular dash that was cut up around the steering column.
Thanks for the help.
