body numbers location A12 #1589941
03/08/14 03:46 PM
03/08/14 03:46 PM
Victoria B C Canada
black hp2 Offline OP
Victoria B C Canada
Hello I am looking for information about the location of body numbers I am looking a an A12 Bee for sale it has no body number on the rad support because its been changed and it does not have a number on the drivers side trunk seal area its just not there it has the fender tags and the dash serial numbers with the original rivets is there a place on the fire wall that has ant numbers I know the E bodys have a body number on the firewall does anyone know if where else I can look for a body number I dont want to buy a rebodied car thanks for any info you guys can help me with.
Re: body numbers location A12 [Re: black hp2] #1589942
03/08/14 03:57 PM
03/08/14 03:57 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Unless you want a car that will always suspect, then pass. No numbers anywhere means it's should be bargain basement price. Do you have a pic of the gas filler neck hole when you pull the license plate down?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: body numbers location A12 [Re: AZ_A12_BEE] #1589943
03/08/14 04:48 PM
03/08/14 04:48 PM
Victoria B C Canada
Victoria B C Canada
I do not have a picture but the guy did point out and show me that its oval shaped do you know of a serial number on the firewall I know they stamped the ebodys found the firewall number on my 70 RT challenger
Re: body numbers location A12 [Re: black hp2] #1589944
03/08/14 05:00 PM
03/08/14 05:00 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
No other numbers, car is screwed till a crook adds some stamps
Re: body numbers location A12 [Re: black hp2] #1589945
03/09/14 12:51 PM
03/09/14 12:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , the only 2 parts that the car has to say it is an A12 BOLT ON , if there are no numbers in the body and you are buying the car as an INVESTMENT ... WALK AWAY and KEEP LOOKING ...
Re: body numbers location A12 [Re: JohnRR] #1589946
03/09/14 12:57 PM
03/09/14 12:57 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
No , the only 2 parts that the car has to say it is an A!@ BOLT ON , if there are no numbers in the body and you are buying the car as an INVESTMENT ... WALK AWAY and KEEP LOOKING ...
