Hello I am looking for information about the location of body numbers I am looking a an A12 Bee for sale it has no body number on the rad support because its been changed and it does not have a number on the drivers side trunk seal area its just not there it has the fender tags and the dash serial numbers with the original rivets is there a place on the fire wall that has ant numbers I know the E bodys have a body number on the firewall does anyone know if where else I can look for a body number I dont want to buy a rebodied car thanks for any info you guys can help me with.
Unless you want a car that will always suspect, then pass. No numbers anywhere means it's should be bargain basement price. Do you have a pic of the gas filler neck hole when you pull the license plate down?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
