Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Jeepmon] #1589807
03/12/14 01:08 PM
03/12/14 01:08 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
All I know is, today is exactly 4 weeks since I ordered my rockers from T&D for a pair of Edelbrock RPM heads, for my Wedge build. It didn't take that long to get custom blower pistons from Diamond.
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Nitrojunkee] #1589808
03/13/14 11:31 AM
03/13/14 11:31 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Jesel Doesnt seem as popular for the B1 stuff. Im looking at buying some new ones too.. Also was told the new T&D rockers wont fit under the old style B1 valve cover cause of the new design???
Have to go to custom Covers...
WTF??
Thats why now the rockers are $1400 plus new valve covers.. Im looking at Jesel.
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Bob_Coomer] #1589809
03/13/14 06:50 PM
03/13/14 06:50 PM
COLUMBUS, OH
W
Whompin_Wedge Offline
W
COLUMBUS, OH
The new B1 covers all tall enough
Casey
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Bob_Coomer] #1589810
03/13/14 07:45 PM
03/13/14 07:45 PM
Arizona
Chris'sBarracuda Offline OP
Arizona
WTF??
The "Paired Rockers" won't fit under any cast B1 cover. Single shaft will fit under my early small B1 covers.
Chris..
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Chris'sBarracuda] #1589811
03/13/14 09:00 PM
03/13/14 09:00 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Chris..
Mine were able to fit Chris.. without any modifications, however I have to heavily clearance the Williams Bro valve covers I bought..
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Jeepmon] #1589812
03/14/14 02:37 AM
03/14/14 02:37 AM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Chris,
I have paired shaft rockers and they fit under a B1 cover.
I would recommend a set of those rockers over the single shaft set.
I also have 1.625" springs.
Call and ask for Brad.
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Biginchmopar] #1589813
03/14/14 11:36 AM
03/14/14 11:36 AM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
I received my T&D's a day ago, and they came in a T&D box as well as having the T&D logo on the rockers...T&D stickers too lol.
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Nitrojunkee] #1589814
03/14/14 11:44 AM
03/14/14 11:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Was this for a SB?... all my SB stuff has been this way
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Biginchmopar] #1589815
03/14/14 12:19 PM
03/14/14 12:19 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Chris,
My paired shaft T&D's would fit under my B1 covers? The rocker tip hits the front rail...
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: MR_P_BODY] #1589816
03/14/14 12:25 PM
03/14/14 12:25 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
No. But it is just an RPM headed 496" Wedge.
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Nitrojunkee] #1589817
03/14/14 01:45 PM
03/14/14 01:45 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
My old cast B1 covers(short ones)fit over my paired T&D's fine. The fabbed sheet metal ones needed the rails clearance a bit.
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Al_Alguire] #1589818
03/14/14 04:32 PM
03/14/14 04:32 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
T&D puts Indy on the rockers we buy from them as well.
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Al_Alguire] #1589819
03/14/14 04:51 PM
03/14/14 04:51 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
Them short covers you sold me Al I had to do a little clearanceing on the rocker adjuster side to make them fit but they clearanced well without hacking them up mine are Jesel paired
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Cheatham] #1589820
03/14/14 06:01 PM
03/14/14 06:01 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Be careful when relieving the T&D rockers if you are running a lot of spring pressure (700+ lbs). My previous set were used with the 1.65" spring and required relieving which reduced their life to about 200 runs. They were breaking like clockwork at that point. Called T&D and they said DO NOT RELIEVE the rockers or they will fail. I went to a 1.55 spring and the rockers did not require relieving. Also, T&D does not like the use of offset keepers to gain installed height. It puts the retainor too close to the rocker.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Dads426] #1589821
03/14/14 10:23 PM
03/14/14 10:23 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I shouldve been more clear what i meant was i had to relieve the valve cover to gain clearance no way would i put a scratch on them rockers
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Dads426] #1589822
03/14/14 11:10 PM
03/14/14 11:10 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
I feel like the luckiest guy on the planet for breaking 1 440-1 rocker in 15 years...with comp 948 springs and Indy black 1.5 nothing special rockers to 7600.
The little old lady from Pasadena is back!
Re: NEW T&D Rockers Say "COMP CAMS" Say What?? [Re: Barnstorm] #1589823
05/02/14 09:06 PM
05/02/14 09:06 PM
Arizona
Arizona
Have an Update:
Sheldon at T&D fixed the situation and made everything right..
Nice to see these days.. At NO COST to me..
Just thought I should post the good with the bad..
Chris..
