Re: NEW T&D Rockers Say "COMP CAMS" Say What??
[Re: Nitrojunkee]
#1589808
03/13/14 11:31 AM
03/13/14 11:31 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Jesel Doesnt seem as popular for the B1 stuff. Im looking at buying some new ones too.. Also was told the new T&D rockers wont fit under the old style B1 valve cover cause of the new design??? Have to go to custom Covers... WTF?? Thats why now the rockers are $1400 plus new valve covers.. Im looking at Jesel.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1589810
03/13/14 07:45 PM
03/13/14 07:45 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
The "Paired Rockers" won't fit under any cast B1 cover. Single shaft will fit under my early small B1 covers.
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Chris'sBarracuda]
#1589811
03/13/14 09:00 PM
03/13/14 09:00 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
Chris..
Mine were able to fit Chris.. without any modifications, however I have to heavily clearance the Williams Bro valve covers I bought..
[Re: Jeepmon]
#1589812
03/14/14 02:37 AM
03/14/14 02:37 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Chris, I have paired shaft rockers and they fit under a B1 cover. I would recommend a set of those rockers over the single shaft set. I also have 1.625" springs. Call and ask for Brad. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Nitrojunkee]
#1589814
03/14/14 11:44 AM
03/14/14 11:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I received my T&D's a day ago, and they came in a T&D box as well as having the T&D logo on the rockers...T&D stickers too lol.
Was this for a SB?... all my SB stuff has been this way ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Biginchmopar]
#1589815
03/14/14 12:19 PM
03/14/14 12:19 PM
Posts: 916 SE Washington
Forest
SE Washington
My paired shaft T&D's would fit under my B1 covers? The rocker tip hits the front rail...
[Re: MR_P_BODY]
#1589816
03/14/14 12:25 PM
03/14/14 12:25 PM
Posts: 47 CO
Nitrojunkee
CO
No. But it is just an RPM headed 496" Wedge.
[Re: Nitrojunkee]
#1589817
03/14/14 01:45 PM
03/14/14 01:45 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
My old cast B1 covers(short ones)fit over my paired T&D's fine. The fabbed sheet metal ones needed the rails clearance a bit.
[Re: Al_Alguire]
#1589819
03/14/14 04:51 PM
03/14/14 04:51 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Them short covers you sold me Al I had to do a little clearanceing on the rocker adjuster side to make them fit but they clearanced well without hacking them up mine are Jesel paired
[Re: Dads426]
#1589821
03/14/14 10:23 PM
03/14/14 10:23 PM
Cheatham
corpus christi tex
Be careful when relieving the T&D rockers if you are running a lot of spring pressure (700+ lbs). My previous set were used with the 1.65" spring and required relieving which reduced their life to about 200 runs. They were breaking like clockwork at that point. Called T&D and they said DO NOT RELIEVE the rockers or they will fail. I went to a 1.55 spring and the rockers did not require relieving. Also, T&D does not like the use of offset keepers to gain installed height. It puts the retainor too close to the rocker.
I shouldve been more clear what i meant was i had to relieve the valve cover to gain clearance no way would i put a scratch on them rockers ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Barnstorm]
#1589823
05/02/14 09:06 PM
05/02/14 09:06 PM
Chris'sBarracuda
Arizona
Have an Update: Sheldon at T&D fixed the situation and made everything right.. Nice to see these days.. ![](/ubbthreads/images/graemlins/bow.gif) At NO COST to me.. ![](/ubbthreads/images/graemlins/thumbs.gif) Just thought I should post the good with the bad.. Chris.. ![](/ubbthreads/images/graemlins/punkrocka.gif)
