74 'cuda disc brake conversions????????? #1589058
03/07/14 12:12 AM
03/07/14 12:12 AM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Tried ssbc kit but does not work with factory rear sway bar. Wilwood can't tell me if theirs will work or not. Anybody know of a kit that will????
Re: 74 'cuda disc brake conversions????????? [Re: scoutsr2] #1589059
03/07/14 12:29 AM
03/07/14 12:29 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
is this for the rear? If so you can go with the dr. diff 11.7" kit with cobra calipers
Re: 74 'cuda disc brake conversions????????? [Re: scoutsr2] #1589060
03/07/14 03:05 AM
03/07/14 03:05 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have Dr. Diff's 13" fronts with 4 piston calipers and his 11.7" Cobra caliper rears on my 73 Cuda. Along with Hydroboost my car stops so much better. Too much stopping power actually, I can't even heel toe anymore the brakes are so sensitive. I think I may need to adjust the Hydroboost.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 74 'cuda disc brake conversions????????? [Re: RylisPro] #1589061
03/07/14 05:33 AM
03/07/14 05:33 AM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Rylis, what wheels are you using that fit the 13" fronts? I know the YO wheels won't fit so I'm curious as to what does.
Re: 74 'cuda disc brake conversions????????? [Re: shawge] #1589062
03/07/14 05:59 AM
03/07/14 05:59 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I am currently using a pair of Enkei PF01's which are my rear rain wheels and a 1 inch adapter for the fronts.
I used these to measure for a set of custom backspace forged 1 piece wheels
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 74 'cuda disc brake conversions????????? [Re: dangina] #1589063
03/08/14 12:29 AM
03/08/14 12:29 AM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Yes this is for the rear for now but might be willing to use complete kit. Just figured someone would have a nice kit that would be known to fit an original rear with sway bar. Do these Cobra calipers have writing on them? Sure would not want a caliber that said cobra showing thru my wheel.
Re: 74 'cuda disc brake conversions????????? [Re: scoutsr2] #1589064
03/09/14 12:39 AM
03/09/14 12:39 AM
dangina Offline
dangina  Offline
they are just a black caliper which I like, I can't see it being even close to hitting the rear sway bar, I'm not sure how any kit would, bu then again I never owned a cuda
