Trans Brake -Which one? #1588538
03/05/14 03:49 PM
03/05/14 03:49 PM
Carson City, Nevada
Biginchmopar Offline OP
Carson City, Nevada
I want to know which Brand of Trans Brake I should buy for a Small Block 727.
It is going in a Mild 340 duster bracket car.
Re: Trans Brake -Which one? [Re: Biginchmopar] #1588539
03/05/14 04:05 PM
03/05/14 04:05 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Always heard Griner's had the quickest release. It would be top of my list. Also, likely most expensive. Not sure if they have a low band apply version. I do believe A&A's is low band apply which is always a nice feature for a street/strip car.
Re: Trans Brake -Which one? [Re: 80fbody] #1588540
03/05/14 07:29 PM
03/05/14 07:29 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
A&A or ProTrans.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: Trans Brake -Which one? [Re: MRMOPAR] #1588541
03/05/14 08:10 PM
03/05/14 08:10 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
My tranzact works great
Re: Trans Brake -Which one? [Re: rickraw] #1588542
03/05/14 09:39 PM
03/05/14 09:39 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I 2nd Transact of Indy.
Re: Trans Brake -Which one? [Re: Sammy] #1588543
03/05/14 09:41 PM
03/05/14 09:41 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
got 3 transzacts in 904s....one was bought back in 1993...all working..
Tony
70 AARCuda Vitamin C
Re: Trans Brake -Which one? [Re: Biginchmopar] #1588544
03/05/14 09:46 PM
03/05/14 09:46 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Steve Grinder I believe perfected the Trans Brake for the 727 904 Trans, My transmission guy said they are the best for 727 904 here is his # 765-296-2955 call after 2pm I have had mine for 5 years now zero problems.
Re: Trans Brake -Which one? [Re: Biginchmopar] #1588545
03/05/14 10:58 PM
03/05/14 10:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I still run my old T/A brake... its the old non LBA
but I'm happy with it... its been said that the LBA
brake will slow the car up some.. I dont know about
this for fact because I never changed over
Re: Trans Brake -Which one? [Re: MR_P_BODY] #1588546
03/06/14 12:56 AM
03/06/14 12:56 AM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
I had a griner for 20 years and worked perfect every time. Just bought a new LBA griner...the best..Just my Two cents
Re: Trans Brake -Which one? [Re: Plymouth340] #1588547
03/06/14 03:44 AM
03/06/14 03:44 AM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
What is the LBA griner brake?
Re: Trans Brake -Which one? [Re: mokid] #1588548
03/06/14 04:32 AM
03/06/14 04:32 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have an A&A LBA brake, works extremely well, good for holeshots, never had an issue. have 2 fellow racers with Griners, both have had solenoid issues but both reckon theirs are better, i'm sticking with the A&A
Re: Trans Brake -Which one? [Re: rebel] #1588549
03/06/14 04:45 AM
03/06/14 04:45 AM
jax. fla.
70Dustmite440 Offline
jax. fla.
I can't remember if I have a Griners or A/A MVB, kinda wish I had bought the trans brake version tho..
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: Trans Brake -Which one? [Re: 70Dustmite440] #1588550
03/06/14 02:08 PM
03/06/14 02:08 PM
Fancy Farm Ky
W
wyoming Online content
wyoming  Online Content
W
Fancy Farm Ky
Pro Trans is pretty hard to beat IMHO
Re: Trans Brake -Which one? [Re: wyoming] #1588551
03/06/14 03:25 PM
03/06/14 03:25 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
A1 clean neutral for me.
Re: Trans Brake -Which one? [Re: mopacltd] #1588552
03/06/14 07:53 PM
03/06/14 07:53 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I think the TCI is made by griner as it has a billet body. I also have a pro tranz, they both work great for me.
Re: Trans Brake -Which one? [Re: DavidDean] #1588553
03/07/14 02:07 PM
03/07/14 02:07 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Can't go wrong with a low band apply Griner!
Re: Trans Brake -Which one? [Re: 496 A-body] #1588554
03/07/14 03:26 PM
03/07/14 03:26 PM
If your going to the expense of buying a trans brake for drag racing replace the front cast iron drum so you eliminate the potential grenade If you do that you don't realy need the low band apply valve body any more as a safety factor,correct? Ask Griner if his trans. brake valve body with low band apply is slower or better than his non low band apply trans. brake valve body I remember seeing posts on here by racers that had tried both LBA and non LBA valve bodys, all of the ones I remember where slower with LBA
Re: Trans Brake -Which one? [Re: Cab_Burge] #1588555
03/07/14 05:16 PM
03/07/14 05:16 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
TransAct of Indy.
Re: Trans Brake -Which one? [Re: FastmOp] #1588556
03/07/14 07:42 PM
03/07/14 07:42 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Cope use to sell Grinners but now only sells the A&A so what does that tell you?
Re: Trans Brake -Which one? [Re: rebel] #1588557
03/07/14 08:01 PM
03/07/14 08:01 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have a tranzact in my turbo car. It's been flawless...
That being said... Joe is a real PAIN to get a hold of from my experiance. I haven't had to call him often on trans questions/parts purchases, but it's been difficult each time.
A&A or CRT will answer the phone/get back with you a lot quicker in my experience.
