Pro Comp Small Block Heads #1587307
03/03/14 11:57 AM
03/03/14 11:57 AM
Pittsburgh Pa
b5fish73 Offline OP
b5fish73  Offline OP
Pittsburgh Pa
I broke down and bought a set of bare heads and their valve train set of the new Pro Comp LA heads. The flow numbers are pretty decent and comparable, if not better than the Edelbrocks. I have a whopping $730 in these heads and couldn't be happier with the quality. The service on the other hand was really lacking. They sent the wrong spring cups and had to call 10 times to get the correct ones. I know I'm going to get some response back about them being "Made in China" but anyways here are the flow numbers OOTB with 2.05/1.60 valves. They are right in line with my ported RHS magnum heads.
@28"
Lift INT EXH
.100 69.5 63.1
.200 130.4 103.4
.300 182.6 139.4
.400 227.5 164.2
.500 245.7 175.3
.600 252.3 180.2
Re: Pro Comp Small Block Heads [Re: b5fish73] #1587308
03/03/14 12:18 PM
03/03/14 12:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'm going to buy a set one of these days to port and see how they compare to ported Edelbrocks. Who did you buy them from?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pro Comp Small Block Heads [Re: pittsburghracer] #1587309
03/03/14 12:23 PM
03/03/14 12:23 PM
Pittsburgh Pa
b5fish73 Offline OP
b5fish73  Offline OP
Pittsburgh Pa
Bought them from Pro Comps ebay sales. I believe the seller was speedmasterusa. They dont look as chunky as the Edelbrocks. They look a little more like a casting than the billet block thats machined. To each their own.
Re: Pro Comp Small Block Heads [Re: b5fish73] #1587310
03/03/14 02:20 PM
03/03/14 02:20 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
@28"
Lift INT EXH
.100 69.5 63.1
.200 130.4 103.4
.300 182.6 139.4
.400 227.5 164.2
.500 245.7 175.3
.600 252.3 180.2
Making sure I am reading this correctly, but your PORTED RHS heads, wont outflow these numbers you have posted? They SHOULD crush those numbers, but maybe I am not understanding something here...
RIP Monte Smith
Re: Pro Comp Small Block Heads [Re: CompWedgeEngines] #1587311
03/03/14 05:06 PM
03/03/14 05:06 PM
Az
Crizila Offline
Crizila  Offline
Az
@28"
Lift INT EXH
.100 69.5 63.1
.200 130.4 103.4
.300 182.6 139.4
.400 227.5 164.2
.500 245.7 175.3
.600 252.3 180.2
Blew those #"s away with a set of home ported 2.02 / 1.60 915 LA castings.
Fastest 300
Re: Pro Comp Small Block Heads [Re: Crizila] #1587312
03/03/14 05:16 PM
03/03/14 05:16 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
@28"
Lift INT EXH
.100 69.5 63.1
.200 130.4 103.4
.300 182.6 139.4
.400 227.5 164.2
.500 245.7 175.3
.600 252.3 180.2
This all depends on who's bench it was on and if they were tested side by side....
I've seen more then one bench ready happy and the next be completely different.
Re: Pro Comp Small Block Heads [Re: DJVCuda] #1587313
03/03/14 07:33 PM
03/03/14 07:33 PM
sweden
sshemi Offline
sshemi  Offline
sweden
I am ythinking a buying the cnc ported bare version.
Figured if it is cnc ported atleast the ports should be all the same?
Think they was like $900
Re: Pro Comp Small Block Heads [Re: sshemi] #1587314
03/03/14 08:40 PM
03/03/14 08:40 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
There CNC version of anything is a waist of time. I talked to them about a year ago about a set of small block Chevy heads I had here for a customers engine. The guy said all they do is map a stock port and add .010 to it. Just enough to show they were CNC's all the way through.
I will look at the SBM heads for a budget 340 I am thinking about doing for my Dart.
Re: Pro Comp Small Block Heads [Re: stroked470] #1587315
03/03/14 08:52 PM
03/03/14 08:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would be the first time I've heard that... most
shops that CNC they do a hand porting based on the
flow then read it to a CNC program.... but maybe that
company does that crap
Re: Pro Comp Small Block Heads [Re: MR_P_BODY] #1587316
03/03/14 11:16 PM
03/03/14 11:16 PM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
Maybe they should've stolen the design from a ported Edelbrock, not one OOTB.
Re: Pro Comp Small Block Heads [Re: justinp61] #1587317
03/03/14 11:20 PM
03/03/14 11:20 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Ive seen some numbers from a reliable source on cnc Pro Comps and they are more than just a casting that has had a little taken out of them to touch up the ports
Keith
Re: Pro Comp Small Block Heads [Re: Dunnuck Racing] #1587318
03/04/14 10:18 AM
03/04/14 10:18 AM
Pittsburgh Pa
b5fish73 Offline OP
b5fish73  Offline OP
Pittsburgh Pa
These were my numbers on my ported RHS magnums. These are off of the exact same bench. I agree some benchs give off some real happy numbers. These are off the same one so you be the judge.
As Cast 1.92int -- Ported 2.02int
---- Int----Exh----Int----Exh
.100 67.4 - 62.2 - - 72.6 - 64.7
.200 115.1 - 111.6 - 133.6 - 113.1
.300 163.0 - 151.2 - 188.6 - 156.2
.400 190.2 -172.5 - 230.0 - 188.1
.500 205.2 - 178.4 - 248.1 - 190.2
.600 212.0 - 178.9 - 257.5 - 193.0
.700 ------ ------ - 261.1- -----
Re: Pro Comp Small Block Heads [Re: b5fish73] #1587319
03/04/14 12:48 PM
03/04/14 12:48 PM
Syracuse,NY
Syracuse,NY
Did you ever dyno the RHS motor,or better yet, what kind of ET and MPH did it run ?
I understand the differences in benches. Yours will be a good comparison because if the common bench. Since your in Pittsburg, why dont you run them over to John for a second comparison ( either head)
RIP Monte Smith
Re: Pro Comp Small Block Heads [Re: CompWedgeEngines] #1587320
03/04/14 01:23 PM
03/04/14 01:23 PM
PA.
"Little"John
"Little"John
PA.
I'll check them both for free (if I don't have to clean them) but I have a small block chevy engine to finish this week so it will have to be next week. It will be some good info for Moparts.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Pro Comp Small Block Heads [Re: pittsburghracer] #1587321
03/04/14 04:40 PM
03/04/14 04:40 PM
Pittsburgh Pa
b5fish73 Offline OP
b5fish73  Offline OP
Pittsburgh Pa
The RHS magnums are on my 408 right now and don't really care to take them off. I can post some time with that truck hopefully this year. Id be more than happy to let you throw the pro comps on your bench. Shoot me a PM and we can figure something out. Thanks
Re: Pro Comp Small Block Heads [Re: b5fish73] #1587322
03/04/14 04:48 PM
03/04/14 04:48 PM
PA.
"Little"John
"Little"John
PA.
PM sent.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Pro Comp Small Block Heads [Re: b5fish73] #1587323
03/04/14 04:54 PM
03/04/14 04:54 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
All I can add re: the Procomp (now "Speedmaster") CNC-ported heads are what I saw w/ their big-block Victor "clone" head.
1. Looked like an attempt at "real" porting, rather than simply opening up the as-cast runner
2. Quite a few drop-outs where the casting was untouched by the program, especially in the chambers. Any claim of getting "identical" ports from having CNC porting goes right out the window when you see that sort of stuff.
3. On the bb head, the CNC program doesn't "fix" issues like the casting under-hanging the exhaust seat inserts leaving a "dead zone" (step) below the insert
I'd like to test one on my bench, considering the Victor (and Victor "clone") data I have so far, but wasn't impressed enough by what I saw to want to buy them. - Brad
Re: Pro Comp Small Block Heads [Re: BradH] #1587324
03/08/14 12:41 AM
03/08/14 12:41 AM
Union grove,wi
cj391 Offline
cj391  Offline
Union grove,wi
Just got a pair of the cnc'd big block procomps. I will attempt to post some pictures, from a phone
Re: Pro Comp Small Block Heads [Re: cj391] #1587325
03/08/14 12:43 AM
03/08/14 12:43 AM
Union grove,wi
cj391 Offline
cj391  Offline
Union grove,wi
'nuther one
Re: Pro Comp Small Block Heads [Re: cj391] #1587326
03/08/14 12:44 AM
03/08/14 12:44 AM
Union grove,wi
cj391 Offline
cj391  Offline
Union grove,wi
one more
