Re: New carb recommendation [Re: StealthWedge67] #1582491
02/24/14 01:09 AM
02/24/14 01:09 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Hey stealth...where did your post go...was replying to it and it said it was deleted?
11.84...impressive, how you got it set up?
Not sure.... My computer went dead while I was editing it, now its gone. ??
My post was replying to Mikes (Mr P-Body) post. I put your general specs through the Holley website carb selector, and came up with an 870 cfm vacuum secondary carb, or an 850 mechanical carb, both of which seem spot on to me for your car. Mike knows his stuff, and I will generally read with eyes wide open everything he writes. In this case, I think we need to keep in mind that you're not asking for Race Car advice. As I understand it, this is a strong running street car that may see the strip now & then (??). With a tight converter and 3.55 gears, I may tend to stick with a vacuum secondary carb, and the 870 is probably a great choice.
Regarding my car, Its a .040 over 400 / 451 combo, and I run an 830-cfm Race series double pumper. But I also run a 9-1/2 converter and 3.91 gears. It may be a little faster with a bigger carb, but it has real crisp throttle response, and runs great on the street with the 830.
Is that the 830 annual discharge chokeless carb? What is the rest of your build?
Re: New carb recommendation [Re: GTX MATT] #1582492
02/24/14 01:55 AM
02/24/14 01:55 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
No, its a downleg carb (#4788).
As I said above, its a .040 over 400, with a forged 3.75 RB crank cut down to fit the B block. Bottom is studded, running Scat H-beam rods and Iconn forged pistons, 10.5:1. As cast Stealth heads with an RPM intake and the 830 DP. Cam is an Engle solid-lifter custom grind that Moparts member Jeff Patterson helped spec. It runs 1-7/8" headers and is sparked by an MSD Digital 6-plus box firing a Mallory Mag-Pickup distributor. Based on weight & MPH, calculators say I'm getting about 450 hp to the rear wheels, so I figure it makes somewhere north of 500 at the crank.
The rest of it is a 727 with a T/A manual valve body and a Dynamic 9-1/2" converter, custom built for my car by the guys at Lupo. 3.91's out back and 27" 255/60-15's and Calvert split mono's and Cal-Trac bars.
Its a great street car that's a lot of fun to drive, and the best part is that I've done all the work on it myself with hand tools in my garage.
Re: New carb recommendation [Re: StealthWedge67] #1582493
02/24/14 02:29 AM
02/24/14 02:29 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I remember you were running the Stealths, do you remember the specs on the cam?
Re: New carb recommendation [Re: GTX MATT] #1582494
02/24/14 02:56 AM
02/24/14 02:56 AM
Puyallup, WA
Puyallup, WA
This is now a full on hi-jack, and I appologize. Cam is a square pattern ground on a 108* cl, 283* running duration, 252* @ .050, .573 lift. Installed straight up, runs at about .018 lash.
Re: New carb recommendation [Re: StealthWedge67] #1582495
02/24/14 03:09 AM
02/24/14 03:09 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yeah sorry to hijack OP, you're close to me on cam specs and overall combo so I had to ask
Re: New carb recommendation [Re: B3422W5] #1582496
02/24/14 03:34 PM
02/24/14 03:34 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Kit up the carb you have.
What is meant by this exactly? What would you guys do with the carb I have to improve it?
Re: New carb recommendation [Re: dwbiggs] #1582497
02/24/14 10:33 PM
02/24/14 10:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Depends on how much you're willing to tune vs. wanting to just bolt-on and go (more or less).
For what you've described, I'd probably...
- buy a Proform replacement main body
- buy a secondary metering block conversion kit
- buy a quick-change top for the vacuum secondary pod & spring kit
- open up the primary block PVCR to .055", if it's smaller currently
- stick a 6.5" power valve in it
- get a range of jets from #70 through #84 and set it up to start with using #72 primary & #80 secondary
- buy some extra squirters to have at least .028", .031", .033" & .035" to try out (but it'll probably be too fat w/ the .035")
- pick up a pack of different accelerator pump cams to try w/ the different nozzles
But, then again, I like to tune things... If you don't, I still suggest contact AED in Richmond about what they suggest to upgrade it and, maybe, sending them the carb for them to do the work.
BTW, your profile location still says VA; didn't realize you were in FL now.
Re: New carb recommendation [Re: BradH] #1582498
02/24/14 11:38 PM
02/24/14 11:38 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Hey thanks Brad...actually just moved down here in July.
Will go ahead and try these upgrades...car runs real good right now but I like to tinker myself. If I can get a smoother idle at least I'd be happy.
Re: New carb recommendation [Re: dwbiggs] #1582499
02/25/14 11:48 AM
02/25/14 11:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
FWIW the Proform main body flows 823cfm.
Re: New carb recommendation [Re: dwbiggs] #1582500
02/25/14 01:15 PM
02/25/14 01:15 PM
BradH Offline
BradH  Offline
Two other things came to mind, especially because you'd mentioned the idle characteristics a couple of times.
1. Where's your ignition curve set up, both initial timing & total?
2. Your primary metering block IFR (Idle Feed Restriction) may need to be enlarged SLIGHTLY to provide more fuel on the idle circuit w/ the bigger cam. How many turns out are your idle mixture screws now?
Both of the above can have a pretty major impact on how it idles.
Re: New carb recommendation [Re: BradH] #1582501
02/25/14 01:24 PM
02/25/14 01:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I see he does mention idle a few times... if thats
all he is concerned about then stay with the carb
you have and play with the idle as Brad said... if
the mixture screws are more than 2 turns out then
he might have to mess with the IFR holes... but as
Brad also said the timing is number one to look at..
it might need some curve work done on it
Re: New carb recommendation [Re: MR_P_BODY] #1582502
02/25/14 08:24 PM
02/25/14 08:24 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Just installed a Quick Fuel Q 850 on my 360 and it runs great, the throttle response is night and day over the holley
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: New carb recommendation [Re: 65signet] #1582503
02/26/14 09:26 PM
02/26/14 09:26 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Been a while but I think I set it up with 15 initial, 35 total all in by 2500 maybe...No VA Have to check the idle screws but don't remember having to turn them more than 2 turns.
Re: New carb recommendation [Re: dwbiggs] #1582504
02/26/14 09:32 PM
02/26/14 09:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your initial could be a bit low which will effect the
way the carb acts.. might want to try it up at about
19* but then your gonna have to cut down the total
which is re-curve work... try moving the timing up
while turning the idle down(as you increase the timing
it will increase the RPM).. see where it idles the
best
