New carb recommendation #1582471
02/22/14 06:48 PM
02/22/14 06:48 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Time to upgrade my carb...given the specs on my car...in sig...what would be a good performance carb over the 80508 Holley I have on it. Never changed anything on present carb...it runs well but figured I could get something more tunable for better idle and performance.
Thanks!
Re: New carb recommendation [Re: dwbiggs] #1582472
02/22/14 06:52 PM
02/22/14 06:52 PM
Central NC
gch Offline
gch  Offline
Central NC
Probably runs pretty well but I may consider a 950hp vacuum secondary with the 3,55's.I am sure I am in the minority.Most will recommend a double pumper and that will work fine also.
Try to borrow an 850 and see if the car like it.
Re: New carb recommendation [Re: dwbiggs] #1582473
02/22/14 07:24 PM
02/22/14 07:24 PM
SoCal
Brian Hafliger Offline
SoCal
Thanks!
Can you fit a 1" open spacer under the current carb? Or 1/2" spacer?
It will clean up the fuel curve of that 850, and you could just KIT the carb.
Brian
Brian Hafliger
Re: New carb recommendation [Re: Brian Hafliger] #1582474
02/22/14 08:08 PM
02/22/14 08:08 PM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
I just love Thermoquads, I have convinced some of my friends to try them and thay also loves them
But they need some tweeking before they run like I want them to run.
Just saying
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: New carb recommendation [Re: MrSixpack] #1582475
02/22/14 10:12 PM
02/22/14 10:12 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Just seems fitting that I should build ya a new carb considering what your last name is....Just Saying..... .Jesse
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: New carb recommendation [Re: BIGS] #1582476
02/22/14 11:18 PM
02/22/14 11:18 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Quick Fuel Annular 950
Re: New carb recommendation [Re: dwbiggs] #1582477
02/22/14 11:32 PM
02/22/14 11:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A 950 DP will work great on that
Re: New carb recommendation [Re: MR_P_BODY] #1582478
02/23/14 12:59 AM
02/23/14 12:59 AM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Wow...950? Guess I am kinda under carbed
Re: New carb recommendation [Re: dwbiggs] #1582479
02/23/14 01:41 AM
02/23/14 01:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A 750 came stock on a 340.. I think you have a touch
more than a stock 340.... dont ya think
Re: New carb recommendation [Re: dwbiggs] #1582480
02/23/14 01:57 AM
02/23/14 01:57 AM
OH, USA
Torred Offline
Torred  Offline
OH, USA
I started out with a 750 DP on a very similar combo. I replaced it with a 950 HP DP from Bigs, adjusted the idle and it performed flawlessly.
Re: New carb recommendation [Re: dwbiggs] #1582481
02/23/14 02:43 PM
02/23/14 02:43 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Thanks!
The 80508 is a 750 vac secondary w/ electric choke, right?
- Do you still want / need a carb w/ choke capability?
- Where does it idle now and what issue do you have with it?
- Have you tried different vac secondary springs out to see how they change how the carb performs?
- Have you switched to add-on secondary metering block to allow jetting changes?
- Are you just looking for it to be more "peppy" on the street, rather than trying to reduce your ETs at the track?
Depending upon your answers, you might want to contact AED in Richmond about converting it to 4-corner idle and re-tuning it based on their own carb work. If you're not looking to chop your ETs down, a better tune w/ that 80508 might be all you need.
BTW, glad you put the heads you bought from me to good use.
Re: New carb recommendation [Re: BradH] #1582482
02/23/14 03:19 PM
02/23/14 03:19 PM
Anoka County, MN
Leigh Online content
Leigh  Online Content
Anoka County, MN
I averaged 10.50's with a 3310, on my 388" small block. A 80496 averaged 10.40's, and the verdict is out on the 8082.
Re: New carb recommendation [Re: Leigh] #1582483
02/23/14 04:57 PM
02/23/14 04:57 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Go to Holley.com, and use their carb-calculator. Their advise is going to be better than most of ours.
Re: New carb recommendation [Re: StealthWedge67] #1582484
02/23/14 05:26 PM
02/23/14 05:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That is used for sizing a carb to a production engine...
if we used that no one would be running quicker
than stock... every time I increase the carb size I
go quicker and faster... right now I run a 1050 dom
on a 405ci.. if I were to follow that calculator I
would need maybe a 750
Re: New carb recommendation [Re: MR_P_BODY] #1582485
02/23/14 08:19 PM
02/23/14 08:19 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Hey Brad...yes I remember getting those heads from you... like 6-7 years ago...surprised you remembered. In Florida now.
The 80508 is a 750 vac secondary w/ electric choke, right? It is
- Do you still want / need a carb w/ choke capability? Not essential
- Where does it idle now and what issue do you have with it? It will idle OK but I figured with a more tunable carb I could get a smoother idle...have VA it ported, may try full vacuum port
- Have you tried different vac secondary springs out to see how they change how the carb performs? Years ago I think
- Have you switched to add-on secondary metering block to allow jetting changes? No
- Are you just looking for it to be more "peppy" on the street, rather than trying to reduce your ETs at the track? strictly street
Car runs great...may just try the metering block you speak of and maybe a proform main body perhaps?
Re: New carb recommendation [Re: dwbiggs] #1582486
02/23/14 08:39 PM
02/23/14 08:39 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
Hey stealth...where did your post go...was replying to it and it said it was deleted?
11.84...impressive, how you got it set up?
Re: New carb recommendation [Re: dwbiggs] #1582487
02/23/14 08:47 PM
02/23/14 08:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You need 3 of them for it run run well duh.. really just get another Holley. The HP series ae very nice. Maybe jump up to an 850.
Coming soon!!!!
Re: New carb recommendation [Re: Mr.Yuck] #1582488
02/23/14 10:16 PM
02/23/14 10:16 PM
Melbourne, FL
dwbiggs Offline OP
super gas
dwbiggs  Offline OP
super gas
Melbourne, FL
I really would like to get a six pack but after looking at the prices... Thought I paid too much when I paid 1500.00 for a set of Pontiac trips.
Re: New carb recommendation [Re: dwbiggs] #1582489
02/24/14 12:36 AM
02/24/14 12:36 AM
Puyallup, WA
Puyallup, WA
Not sure.... My computer went dead while I was editing it, now its gone. ??
My post was replying to Mikes (Mr P-Body) post. I put your general specs through the Holley website carb selector, and came up with an 870 cfm vacuum secondary carb, or an 850 mechanical carb, both of which seem spot on to me for your car. Mike knows his stuff, and I will generally read with eyes wide open everything he writes. In this case, I think we need to keep in mind that you're not asking for Race Car advice. As I understand it, this is a strong running street car that may see the strip now & then (??). With a tight converter and 3.55 gears, I may tend to stick with a vacuum secondary carb, and the 870 is probably a great choice.
Regarding my car, Its a .040 over 400 / 451 combo, and I run an 830-cfm Race series double pumper. But I also run a 9-1/2 converter and 3.91 gears. It may be a little faster with a bigger carb, but it has real crisp throttle response, and runs great on the street with the 830.
Re: New carb recommendation [Re: Brian Hafliger] #1582490
02/24/14 12:48 AM
02/24/14 12:48 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Thanks!
Brian
Yep... Great thought. For it being a street car and not an all out race application, it's unlikely that any carb swap would effect performance significantly enough to feel it in the seat of the pants.
So why throw money at something that isn't broke and most likely won't make a noticeable difference. Kit up the carb you have.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
