Anybody using a DIY alignment tool like this?
#1581694
02/20/14 06:37 PM
02/20/14 06:37 PM
Posts: 51 San Diego, USA
SoCalRacer
San Diego, USA
Anybody doing their own front end alignment? Curious as to the pros/cons of using a tool like the Quick Trick stuff. Quick Trick I would be using it on a tube chassis Plymouth Arrow drag car with rack and pinion and my '70 Cuda... Thanks in advance for facts and opinions!
If it ain't broke ... you're not pushing it hard enough.
Re: Anybody using a DIY alignment tool like this?
[Re: SoCalRacer]
#1581697
02/21/14 01:07 PM
02/21/14 01:07 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've used string to do alignments. One of our bodymen smashed the right rear suspension and subframe on his SLK350 just before a holiday weekend. I stayed late to help him put it back together. The mechanics were long gone so we used his tram gauge to set the alignment. It was amazingly close in all dimensions.
[Re: feets]
#1581698
02/21/14 01:34 PM
02/21/14 01:34 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
I actually use my iphone for checking / adjusting Camber and Caster.
My wheel has a place I can put a 10"x8" piece of lexan or glass, so I put my iphone against that to check angles. I do have turn plates, and there's actually an iphone app that calculates caster (or you can do it by hand with formulas - quite easy math).
IMHO - the biggest thing with an alignment is getting the surface level.
I also have long acre toe plates for setting toe after making adjustments elsewhere.
I aligned my car the first time in my garage, and was pretty equal side to side, but boy is it a bear to get the caster equal when you're starting from nothing.
I prefer to have an alignment done 'professionally', and then I can make changes. My set-up doesn't read exactly what the shop's did, so as long as I keep the 'change in angle' equal side to side and then re-set the toe, I'm good to go.
I'm going to take it back in to the pro's before the Big Bend Open Road Race. Money well spent when going that fast.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: SoCalRacer]
#1581700
02/23/14 03:33 PM
02/23/14 03:33 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
For the money, that's definately better than a tape measure across a rib on the tread and a bubble gauge on the lip of the rim but a see a couple minor flaws.
Compared to a competent mechanic and a laser 4 wheel reference alignment rack, that DIY leave a bit of error on the table.
Using sidewall of the tires for toe? Many sidewalls are not smooth. No self correction of rim runout. Ever see the proper racks check and rotate the tire 180 deg? There is no reference to the centerline or rear tires.... but it's ain't bad.
[Re: 70AARcuda]
#1581705
03/12/14 03:23 AM
03/12/14 03:23 AM
Posts: 27,469 So Cal
autoxcuda
So Cal
I use this one. Very worthwhile investment IMO.
I have driven my one car close to 20k miles so far with good tire wear.
bought one of the Quick Trick Pro...would not fit my wheels...they said send pictures and they would make adapter..I send the thing back...bought the same one shown above...works great on my Draglites..Pro Stars and Centerlines..
Which brand and model number is that one??
[Re: SoCalRacer]
#1581708
03/13/14 12:17 PM
03/13/14 12:17 PM
Challenger 1
Cincinnati, Ohio
I'd like to know as well. Are those turntables under the tires, or a piece of sheetmetal/plate on top of another highly greased plate?
This one is made by SPC I could not find it in summitts site, but Jegs listed it. I think I got mine from Summit for 149 bucks plus another 50 for the toe pieces. Kind of a rip off for 50 bucks, oh well, they work nice. web page The turn plates are nothing more than 14ga steel with grease in between them. The grease is still there today after moving them a few times where as salt would spill and I don't want salt in my shop. Plus I imagine it would make my steel plates rust in time. Flat steel; plates are easy to roll onto and off of after making adjustments allowing the front end to settle after each adjustment. I had to shim one side 3/4" to make them level and it's still easy to roll the car onto them by hand.
So nice to do it yourself and come back and recheck and have it repeat the same readings. Really gave me confidence that it was right and stayed right. I park on top of my turn plates every night and that makes it easy to recheck any time. Too me it helps keep track of front end wear.
