Anybody using a DIY alignment tool like this? #1581694
02/20/14 06:37 PM
02/20/14 06:37 PM
San Diego, USA
SoCalRacer Offline OP
San Diego, USA
Anybody doing their own front end alignment? Curious as to the pros/cons of using a tool like the Quick Trick stuff.
Quick Trick
I would be using it on a tube chassis Plymouth Arrow drag car with rack and pinion and my '70 Cuda...
Thanks in advance for facts and opinions!
If it ain't broke ... you're not pushing it hard enough.
Re: Anybody using a DIY alignment tool like this? [Re: SoCalRacer] #1581695
02/20/14 08:26 PM
02/20/14 08:26 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
We did something similar with our Baja car but ours were just .250" thick (I think) aluminum plates with slots for the tape measures to grab onto. We'd place the plates on the wheels and use a digital angle finder to tell us our camber and we'd use the tape measures to check the toe. I don't think I have a picture of it but it seems rather similar to that product.
Re: Anybody using a DIY alignment tool like this? [Re: SoCalRacer] #1581696
02/20/14 09:23 PM
02/20/14 09:23 PM
Las Vegas, NV
Tom_440 Offline
Tom_440  Offline
Las Vegas, NV
I have the Quick Trick Pro. Customer support is awesome. I never did alignments before and they answered a lot of questions via e-mail promptly. The bars fit most of my vehicles well but I had problems fitting the Cragers. A bungee cord took care of the issue.
I am no pro and if I take a measurement once, and then repeat it, I will probably not get the same measurement the second time. I suppose that's why camber/caster are listed in ranges. Or why I won't quit my day job.
Anyway, its great for a novice like me. Apparently some companies use them on their fleets so it must work. They don't come with turntables which is not a big deal, but important to know.
Re: Anybody using a DIY alignment tool like this? [Re: SoCalRacer] #1581697
02/21/14 01:07 PM
02/21/14 01:07 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've used string to do alignments.
One of our bodymen smashed the right rear suspension and subframe on his SLK350 just before a holiday weekend. I stayed late to help him put it back together. The mechanics were long gone so we used his tram gauge to set the alignment.
It was amazingly close in all dimensions.
- Stu Harmon
Re: Anybody using a DIY alignment tool like this? [Re: feets] #1581698
02/21/14 01:34 PM
02/21/14 01:34 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
I actually use my iphone for checking / adjusting Camber and Caster.
My wheel has a place I can put a 10"x8" piece of lexan or glass, so I put my iphone against that to check angles. I do have turn plates, and there's actually an iphone app that calculates caster (or you can do it by hand with formulas - quite easy math).
IMHO - the biggest thing with an alignment is getting the surface level.
I also have long acre toe plates for setting toe after making adjustments elsewhere.
I aligned my car the first time in my garage, and was pretty equal side to side, but boy is it a bear to get the caster equal when you're starting from nothing.
I prefer to have an alignment done 'professionally', and then I can make changes. My set-up doesn't read exactly what the shop's did, so as long as I keep the 'change in angle' equal side to side and then re-set the toe, I'm good to go.
I'm going to take it back in to the pro's before the Big Bend Open Road Race. Money well spent when going that fast.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Anybody using a DIY alignment tool like this? [Re: Tom_440] #1581699
02/21/14 06:26 PM
02/21/14 06:26 PM
San Diego, USA
San Diego, USA
Thanks for the heads up on turntables. My 'Cuda (it's a drag car too) was done professionally (quite) a while back to specs I got from Sox & Martin's '70 Pro Stocker, which is similar chassis technology. Car always drove beautifully at speed, but hasn't been checked in 15 years...
The Arrow has Pinto front suspension, but the rack & pinion and tie rods were loose when I got it so toe is hosed, but caster and camber should be close. Still want to be sure though at 145+ through the eyes
Re: Anybody using a DIY alignment tool like this? [Re: SoCalRacer] #1581700
02/23/14 03:33 PM
02/23/14 03:33 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
For the money, that's definately better than a tape measure across a rib on the tread and a bubble gauge on the lip of the rim but a see a couple minor flaws.
Compared to a competent mechanic and a laser 4 wheel reference alignment rack, that DIY leave a bit of error on the table.
Using sidewall of the tires for toe? Many sidewalls are not smooth.
No self correction of rim runout. Ever see the proper racks check and rotate the tire 180 deg?
There is no reference to the centerline or rear tires.... but it's ain't bad.
Re: Anybody using a DIY alignment tool like this? [Re: Magnum] #1581701
02/23/14 04:00 PM
02/23/14 04:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's $190, what do you want for that?
Don't be the exception.
Re: Anybody using a DIY alignment tool like this? [Re: Magnum] #1581702
02/24/14 04:08 PM
02/24/14 04:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
We would jack up the tire, put a scribe against part of the tread, and spin the tire. That left a good reference line that could be used on any part of the tire. It also accounted for runout.
It was far from perfect but worked pretty darned well for an impromptu alignment.
- Stu Harmon
Re: Anybody using a DIY alignment tool like this? [Re: SoCalRacer] #1581703
03/07/14 10:43 AM
03/07/14 10:43 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I use this one. Very worthwhile investment IMO.
I have driven my one car close to 20k miles so far with good tire wear.
Re: Anybody using a DIY alignment tool like this? [Re: Challenger 1] #1581704
03/12/14 01:49 AM
03/12/14 01:49 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
bought one of the Quick Trick Pro...would not fit my wheels...they said send pictures and they would make adapter..I send the thing back...bought the same one shown above...works great on my Draglites..Pro Stars and Centerlines..
Tony
70 AARCuda Vitamin C
Re: Anybody using a DIY alignment tool like this? [Re: 70AARcuda] #1581705
03/12/14 03:23 AM
03/12/14 03:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Which brand and model number is that one??
Re: Anybody using a DIY alignment tool like this? [Re: autoxcuda] #1581706
03/12/14 05:31 PM
03/12/14 05:31 PM
San Diego, USA
San Diego, USA
I'd like to know as well. Are those turntables under the tires, or a piece of sheetmetal/plate on top of another highly greased plate?
Re: Anybody using a DIY alignment tool like this? [Re: SoCalRacer] #1581707
03/12/14 07:19 PM
03/12/14 07:19 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
4 tiles and some salt.
A lot less messy than greasing metal.
Re: Anybody using a DIY alignment tool like this? [Re: SoCalRacer] #1581708
03/13/14 12:17 PM
03/13/14 12:17 PM
Cincinnati, Ohio
Cincinnati, Ohio
This one is made by SPC I could not find it in summitts site, but Jegs listed it. I think I got mine from Summit for 149 bucks plus another 50 for the toe pieces. Kind of a rip off for 50 bucks, oh well, they work nice. web page
The turn plates are nothing more than 14ga steel with grease in between them. The grease is still there today after moving them a few times where as salt would spill and I don't want salt in my shop. Plus I imagine it would make my steel plates rust in time.
Flat steel; plates are easy to roll onto and off of after making adjustments allowing the front end to settle after each adjustment. I had to shim one side 3/4" to make them level and it's still easy to roll the car onto them by hand.
So nice to do it yourself and come back and recheck and have it repeat the same readings. Really gave me confidence that it was right and stayed right. I park on top of my turn plates every night and that makes it easy to recheck any time. Too me it helps keep track of front end wear.
