rr wheel tire size #1581495
02/20/14 12:23 AM
02/20/14 12:23 AM
IL
Rawone Offline OP
Rawone  Offline OP
IL
1969 road runner. What best offset on the rear wheels to fit the biggest tire without clearance issues and no rolling or cutting at all. I am thinking a 295 65. 15 , Should I use a 4.25. 4.5. Or 5 inch backspace? Pics appreciated.. also what size radial tire looks good on the front...I assume a 6 x15inch wheel would be a good choice.
I
Re: rr wheel tire size [Re: Rawone] #1581496
02/20/14 12:33 PM
02/20/14 12:33 PM
IL
Rawone Offline OP
Rawone  Offline OP
IL
Was hoping to get some insight....I have read that 5.5 back spacing will work ,however im not sure if the springs were in stock location and not alterex. Seems most use a 4.5 be on a 8 inch rim.
Re: rr wheel tire size [Re: Rawone] #1581497
02/20/14 09:31 PM
02/20/14 09:31 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I'd assume it would depend on what rear end set up you have, brakes, and how high or low you want the rear.
Re: rr wheel tire size [Re: MuuMuu101] #1581498
02/20/14 09:44 PM
02/20/14 09:44 PM
IL
Rawone Offline OP
Rawone  Offline OP
IL
8 3/4 stock uncut housing...stock suspension widest tallest tire I can fit without cutting car up to fit. No rubbing issues...so must have a lil clearance. Body and rear end is stock.whit backspace can I safely get away with...Can i use 4.25 or how much backspace can I get away with without having rub issues. I was hoping someone on here had done this or had thoughts..
Re: rr wheel tire size [Re: Rawone] #1581499
02/20/14 10:05 PM
02/20/14 10:05 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
15x8 with 4.5" backspace is what my buddy used on his '68 Satellite convertible while running 295/65/15 drag radials. Another friend used the same sizes on his '70 Coronet...both have springs in stock location, etc.
Re: rr wheel tire size [Re: Blues_Cuda] #1581500
02/21/14 03:57 AM
02/21/14 03:57 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Stock rear & springs and uncut quarters:
15x8 with 4.5 BS no problem with 295/50R15s.
15x10 with 5.5 BS is tighter, but clears according to the black '69 GTX a member here has (can't recall the name), and IIRC he's running the tire you're talking about.
Re: rr wheel tire size [Re: topside] #1581501
02/22/14 12:18 PM
02/22/14 12:18 PM
IL
Rawone Offline OP
Rawone  Offline OP
IL
I would like to try a 5 or 5.5 backspace, but I better play it safe and get 4.5 backspace on the rear with an 8 inch wheel. I can prob do a 6 or 7 inch on the front not sure what tire size for the front that i will get yet, I don't want the diameter to look too small.
Re: rr wheel tire size [Re: Rawone] #1581502
02/22/14 04:01 PM
02/22/14 04:01 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Most of my buddies run 235/60/15's on the front of their B & E bodies with 7" wheels.
Re: rr wheel tire size [Re: Blues_Cuda] #1581503
02/22/14 11:06 PM
02/22/14 11:06 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
225 or 235 70s on the front of my B bodies, I usually try to match the hiegth of the rear tires. I plan to run a 235 70s on the front of my AAR with 275/60s in the rear, but I like muscle cars to sit high and real close to level.
Careful, your character's showing!
