R3 Block Question #1579003
02/14/14 06:12 PM
02/14/14 06:12 PM
Omaha, NE
dart69bigblock Offline OP
Omaha, NE
Hello all,
I have a question in regards to the R3 block. I have experience with big blocks but none with Mopar small blocks. I am looking at all options for a turbo engine application. I have found a good deal on a
new R3 block. Here are the specs for this particular block:
59 degree tappet angle
4 bolt main
Siamese bore
9.200" Deck
Standard Cam Tunnel
Rough bore 3.900
I have read that the 59 deg tappet blocks are not recommended for roller lifters and I want to run a roller cam. Can anyone verify if that is true and maybe explain why?
Thank you,
Chris
Re: R3 Block Question [Re: dart69bigblock] #1579004
02/14/14 06:44 PM
02/14/14 06:44 PM
Renton Washington
Triple Threat Offline
Renton Washington
Do you already have any parts you would like to use? Heads, camshaft etc?
Factory angle is 59*, 48* blocks also exist for some of the better heads on the market. If you are starting from scratch I would reccomend a 48 degree block. Or buying someones motor thats already together.
I have a 59 degree R3 block with a solid roller. You definitely can run a roller cam, but there is some work required to the valley area needed for clearance.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: R3 Block Question [Re: Triple Threat] #1579005
02/14/14 07:00 PM
02/14/14 07:00 PM
Omaha, NE
Omaha, NE
I do not have anything as of now. Just keeping my eyes open for good deals and throwing around ideas for what I want to do. I am still not settled on a small block. Am open to a new gen hemi or big block stuff still. I like the idea of a small block due to more room for packaging a turbo or two in the engine compartment. This would be going in a 70 RR. and while it seems weird to put a small block in a RR the 1000+ hp I think will make up for that!
Re: R3 Block Question [Re: dart69bigblock] #1579006
02/14/14 08:28 PM
02/14/14 08:28 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The 48 degree motors have much better push rod angles and valve train stability.
Re: R3 Block Question [Re: dart69bigblock] #1579007
02/14/14 10:46 PM
02/14/14 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Rollers work fine in the 59*(just like a stock block)
but the 48* is better... you would be building a stock
block(shorter deck) with thicker cyl walls
EDIT
I would sonic check it but if its decent start at a
4.185 bore... dont mess around with 4.125 bore like
I did.... see if you can find some 59* W-9s
Re: R3 Block Question [Re: dart69bigblock] #1579008
02/15/14 02:52 AM
02/15/14 02:52 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
twins and 1000+ hp.... I'm betting in your research you are going to find that the 48* block and the heavier W8 head will be the weapons of choice.
Re: R3 Block Question [Re: J_BODY] #1579009
02/15/14 04:19 AM
02/15/14 04:19 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
how hard is it to put 59 degree heads on a 48 degree 9.200 deck ???? Could a 59 degrees intake be used ?? Or would I have to mill a w8 /w9 intake ?
Re: R3 Block Question [Re: RAY1969CARS] #1579010
02/15/14 12:25 PM
02/15/14 12:25 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
check out shady dell's site.
Re: R3 Block Question [Re: RAY1969CARS] #1579011
02/15/14 12:34 PM
02/15/14 12:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Remember that its just the lifter angle thats changing..
the deck is still the same but shorter... Ryan (shady dell)
did it but you have a lot of material to be removed
in the push rod area and off set lifters
Re: R3 Block Question [Re: MR_P_BODY] #1579012
02/15/14 03:09 PM
02/15/14 03:09 PM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
what intake did he use ?
Re: R3 Block Question [Re: RAY1969CARS] #1579013
02/15/14 03:47 PM
02/15/14 03:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont recall... the build might be on his site...
I dont remember what heads he used(that would make
a difference on which intake)
Re: R3 Block Question [Re: MR_P_BODY] #1579014
02/15/14 04:58 PM
02/15/14 04:58 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
If you are interested there is a set of worked 59* W9s with Jesel Roller Rockers on Racingjunk. http://www.racingjunk.com/Heads/182136708/mopar-W9-heads-w-rockers.html
Re: R3 Block Question [Re: J_BODY] #1579015
02/16/14 03:48 AM
02/16/14 03:48 AM
Omaha, NE
Omaha, NE
This is exactly what I have found. At least about the block. I have not done too much research on the heads yet.
Thank you for all the input guys. Is there any websites or dealers to get the best deal on an R3 block?
Re: R3 Block Question [Re: dart69bigblock] #1579016
02/16/14 02:52 PM
02/16/14 02:52 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
It depends how much the + means in 1000hp+. If you're talking right around 1000hp, you don't need a 48 degree block or W9 heads to do it.
Around 15psi will basically double the HP of a N/A motor (Give 'er take a little in some cases).
So to make 1000hp, you really only need around 500hp NA to do it. Do you need a W9 head to do that? Of course not.
When I added it up before for my next project, I actually found at that power level the Hemi was the best bang for the buck. Blocks will withstand 1000hp, 6.1L cranks are cheap and will take that power, rocker arms are strong, and the heads will flow plenty enough to do it.
A low deck would also be a good choice because of the block strength, but you'll end up spending a bit more for crank/heads/rockers to do it.
Granted you'll have some expense with the EFI stuff, but the savings on the block/crank/heads/rockers more then offset it.
Want to make significantly more then 1000hp? Then the R3 combo will start to win the price war.
P.S. If you're talking about my block on race junk, it's already sold. http://www.racingjunk.com/Blocks/182127210/Mopar-R3-Block-Brand-New.html
Re: R3 Block Question [Re: dizuster] #1579017
02/16/14 03:17 PM
02/16/14 03:17 PM
Omaha, NE
Omaha, NE
Dizuster- that actually was the block that sparked my curiosity. My right now is around 1000 hp. But as anyone that has ever built a car knows once you reach your power goal, you almost always want more. So not only am I researching for my current goal, but I also want to leave myself room to improve down the road.
I have also done a lot of research I to the hemis. The main concern for me with the stock 6.1 block is the possible oiling problem. Some people say worry about and some say don't. If you look into aftermarket stock crank or stroker kits then it really is about the same price as a big or small block. I like the idea of more room in the engine bay with the small block. From what I can tell the hemi gives you from space in front of the engine over a big block but width is no better because of the size of the heads.
So many choices and decisions out there! If I were to not use the W9 head what would be another good option?
Re: R3 Block Question [Re: dizuster] #1579018
02/16/14 04:19 PM
02/16/14 04:19 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
But you will want an R block or equivalent.
I suppose the 340 resto block is beefy enough.
But at this level , I think the natural choice is 48 degree.
Especially if you have an eye on adding more oats down the road.
Re: R3 Block Question [Re: tubtar] #1579019
02/16/14 06:42 PM
02/16/14 06:42 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Don't worry about the packaging space. There is plenty of room with any option (big block, hemi, or small block) to make it work.
How quick/fast are you trying to go? 1000hp will get a regular 3300lb car down to 8.50 (or better). Beyond that, it needs a funny car style cage, and a lot more certification work.
I'm all for planning ahead, but you are talking about a CONSIDERABLE cost difference between R3/W9 1500hp motor, and a Low Deck/Gen 3 1000hp motor.
Other then the FEW people I have heard on THIS board "saying" there is an issue... I do not believe that there really is a 6.1L oiling issue. Really... do a google search and try to find reference to a 6.1L crank cross drilled issue that didn't stem from this board.
BES told me they have them running over 1000hp without an issue.
HHP said the same thing.
Remember... with the turbo stuff it makes so much torque you don't need to turn killer RPM to make power. My 75mm turbo on a iron headed 360, made 700+ at 5600rpm. The cam was only 224@.050" with .499" lift. So at 6500~7000rpm, what 6.1L oiling issue would you be worried about anyway?
Re: R3 Block Question [Re: dizuster] #1579020
02/16/14 07:12 PM
02/16/14 07:12 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Just curious what factory low deck can take 1000 hp?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R3 Block Question [Re: 1967dartgt] #1579021
02/16/14 07:17 PM
02/16/14 07:17 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Turbo'd? 400 or 383 block... No problem.
Lots of examples out there.
Trendz did it, so did the SDCE challenger.
Re: R3 Block Question [Re: dizuster] #1579022
02/16/14 07:26 PM
02/16/14 07:26 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Pretty sure they both blew up and so did Josh's duster. I thought factory big block had problems at 750 hp levels. I would want to take that chance at those hp levels with stock blocks because if it goes bad you are really moving on the race track. At 1000 hp you will be 150 mph.
