Re: Let the Hemi swap begin
[Re: AlexP]
#1577600
02/16/15 03:29 PM
02/16/15 03:29 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
So my mainstay plan is to use the Android tablet for start up, but I need a permanent solution. Here are my choices: -Restore the taxi cab dash ($600 and I only make it pretty and adequate...) I dont gain any gauges aside from turning the amp gauge into a volt gauge. -Make a plate the same size as the taxi cab dash and try to fit a 3 3/8" Tach and speedo along with 4 2 1/16 gauges. I've seen this done, but it looks cluttered due to the small opening. I've ordered 1100 series aluminum plate in 6x24" to try this. -Cut the dash for a rallye dash cluster (i've got a junk cluster and bezel) and try to adapt a rallye dash pad to the bottom. The fascia should cover it all. This is the preffered option, but riskiest. If it doesn't work I've got a chopped up dash that needs to be completely swapped out to a rallye style. Now there are even digital drop in clusters... -The most expensive option and least inspired option is this one... http://www.ebay.com/itm/1968-70-B-body-N...=item1c4d0eb36bOverpriced and doesn't do much aside from fit in the stock place. Id buy it right now for $500 less than it is. -The simplest and most easily reversible is to get a Racepak Street Dash and bolt it to that .250" aluminum plate with my wideband and go. It can do turn signals, flashers, speedo, tach, water temp, oil pressure, volts and oil temp. That would be simple. I've printed a template of the racepack, if it can fit easily I'll order this. What do all my mopar friends think?
[Re: AlexP]
#1577609
03/24/15 05:00 PM
03/24/15 05:00 PM
Posts: 28,137 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Silly man. You should have asked. I have a pair of Bosch 80 amp relays like that at home. They're destined for my projects.
[Re: AlexP]
#1577611
03/24/15 11:47 PM
03/24/15 11:47 PM
AlexP
Houston, Tx
I can't prove that I worked on it if I didn't take pictures. Installed my $20 Camaro spoiler: Installed the Moroso battery box and got an Autozone AGM battery. NHRA legal...yo. Kinda. I also realized that I'm not as smart as I thought I was. I purchased an LS1 power steering pump to bolt to Emil's bracket, but the clocking is different from the pump he based the kit off of and the reservoir comes out the side instead of the top. DONT BUY AN LS1 PUMP. I'll be buying the Speedway pump like he is using and doing AN fittings to the box.
[Re: AlexP]
#1577612
03/25/15 07:20 AM
03/25/15 07:20 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm contemplating using one on my dual fuel pumps. Just a tiny Holley Pump and a GSL392.
On a related note, I need some advice on powering my fuel pumps. I'd like to locate my fuel pump relays in the trunk of the car close to the battery. I was imagining a small fuse panel for the pumps and a small lug panel to take the power direct to the relays.
How should I wire this?
What are you doing to fuse/protect your alternator output? I am assuming it is going to end up back there to the battery or to your switch?
I used a Blue Sea systems circuit breaker on mine, they make larger current rating models. If this was somewhere in your trunk, you could use one of the lugs to also feed your little fuse box, then to feed your relay[s].
[Re: AlexP]
#1577615
03/26/15 11:47 AM
03/26/15 11:47 AM
AlexP
Houston, Tx
I trimmed 1/2" off of the Thunderbird fan and notched it with a pair of shears and it fits really nicely. A few impromptu brackets and it will be ready to go. Also after much deliberation and a stressed out thread...I got the shifter in. https://board.moparts.org/ubbthreads/show...e=0#Post8470412Now I just need to connect the linkage rod and I can check actuation of the gears. Next I need to order 2 HD 70 amp relays, 3 breakers (fan, fuel pumps and alternator output) and all my supplies to wire the important systems of the car. I've got a GM PS pump on order and the fittings to connect up the PS box from Firm Feel.
