Page 7 of 22 1 2 5 6 7 8 9 21 22
Re: Let the Hemi swap begin [Re: GoodysGotaCuda] #1577459
10/05/14 05:42 PM
10/05/14 05:42 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I am running a solid driver side/rubber pass side on my 6.1 and also ran the same style on my BB for about 14 years. All the alternatives "ACT" just like a solid mount anyway.
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: 72Swinger] #1577460
10/05/14 11:33 PM
10/05/14 11:33 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Headers are in. They're 90% of a perfect fit to the car. They will need denting on the passengers side header with my 1.22" t bars, which I should have expected. If I had a 1.0" ish tb, this wouldn't be a problem.
Both headers snaked in from the bottom without issue. I didn't even have the car very high up at all. I elected to not use the TTI gaskets, instead I picked the composite 6.1 factory gasket.
It was surprising to see the AC compressor and steering box not hit on the drivers side. The notch that I made was more than enough on the k frame.
I will have to pull the headers to make small adjustments, but nothing serious.
As it sits now. I've got the intake on there only to keep dirt and critters out of the motor.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1577461
10/06/14 02:19 AM
10/06/14 02:19 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
LOOKS GOOD!!!
Re: Let the Hemi swap begin [Re: 70blackfish] #1577462
10/06/14 03:10 AM
10/06/14 03:10 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Right on Alex!
Re: Let the Hemi swap begin [Re: 72Swinger] #1577463
10/07/14 10:56 PM
10/07/14 10:56 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I did not see it mentioned, but are you using the front cover/accessory drive stuff (other than the oil filter adapter) from an LX/LC platform car? It looks like it, but I wanted to be sure.
Re: Let the Hemi swap begin [Re: ntstlgl1970] #1577464
10/08/14 03:09 AM
10/08/14 03:09 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
This cover is from an 05-08 car 5.7 or 6.1
Re: Let the Hemi swap begin [Re: AlexP] #1577465
10/08/14 11:01 AM
10/08/14 11:01 AM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
Does it run yet?
Does it run yet?
Does it run yet?
Does it run yet?
- Stu Harmon
Re: Let the Hemi swap begin [Re: feets] #1577466
10/08/14 12:44 PM
10/08/14 12:44 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
No. I still havent pulled the headers back out, but I did mount my throttle body and tidy up the top end. I'm still working parts to figure out what I'm missing.
Re: Let the Hemi swap begin [Re: AlexP] #1577467
10/14/14 11:50 AM
10/14/14 11:50 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I remember you were wanting to get your gauges redone, somebody just posted a restored one. It's 1K though. "68 SAT" is the users name.
Re: Let the Hemi swap begin [Re: 68KillerBee] #1577468
10/14/14 01:00 PM
10/14/14 01:00 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Redline Gaugeworks in LA does all of ours. They are AWESOME.
Re: Let the Hemi swap begin [Re: AlexP] #1577469
10/22/14 11:05 PM
10/22/14 11:05 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I've said it to myself many times, but I must admit...I'm not happy to ding headers. Not even a little bit. But, unfortunately I had to with these TTI's. Mind you, I don't feel that I did the best job that I could beating these (I really should have used a ball peen hammer).
The T-bars hit my passengers side collector severely. I thought that it was the fact that I have 1.22" bars, but there was over a half inch of interference.
Thats the top of the DS header where it passes under the T-bar.
The next area that hit was the #1 tube passing by the AC compressor. If I didn't have AC in mind, this wouldn't be an issue. I had to trim the AC compressor from the start as per 808cuda's post, but I also had to ding it to fit.
I'll give the benefit of the doubt because these headers are from 2007 and weren't used until now. I don't know what changes have been made to the jig. I will say that TTI does have amazing customer service and I wouldn't use any other header for this swap. I have no doubt that Dougs is lightyears behind TTI. I talked to them on the phone and I wasn't impressed.
Right now, they're in and they clear everything. I'm going to make one final change to the headers to make them fit a little better, which will be adding V-band connections to the collector to gain ground clearance. My car is silly low and I don't want those 3 bolt flanges catching on everything. Other than that, they will work well and support a ton of power. For a mild steel header, they are beefy where it counts and are very well coated. I'd be willing to pay double the price for them to be a low grade stainless though.
I'm progressing on my build. I'm ready to leave the front of the car and start ordering fuel system components. The front end is sealed and ready to sit for a while. The engine is sealed from TB to headers. I know it will take me more than one try to get my fittings ordered from Summit.
Re: Let the Hemi swap begin [Re: AlexP] #1577470
10/22/14 11:22 PM
10/22/14 11:22 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I take a piece of 1.5"x.250 wall tubing and put that where I need the dent and hit only that. Makes nicer dents lol.
Re: Let the Hemi swap begin [Re: 72Swinger] #1577471
10/22/14 11:38 PM
10/22/14 11:38 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Trust me, I'm not proud. That's the only part of my build that I'm not proud of.
Re: Let the Hemi swap begin [Re: AlexP] #1577472
10/22/14 11:42 PM
10/22/14 11:42 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Are those the 1-3/4" primaries?
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: AlexP] #1577473
10/22/14 11:47 PM
10/22/14 11:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
It wasn't a poke at you, just a tip for future denting. I also think TTI mounts favor the passenger side a bit to much.
Re: Let the Hemi swap begin [Re: RylisPro] #1577474
10/23/14 12:35 AM
10/23/14 12:35 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
They are. The 2" is unneeded for most applications. I could make 1000hp with my blower and be fine.
Re: Let the Hemi swap begin [Re: AlexP] #1577475
11/03/14 02:35 AM
11/03/14 02:35 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I've moved to the front of the car while I'm waiting on some fuel system parts.
I ordered the following-
(6)1.5" T-bolt Clamps
(1)1.75" T-bolt Clamp
(1)180* Stainless U-bend 1.5"
(1)1.5" to 1.75" Silicone Reducer
My lower radiator hose is from a 5.7 Magnum. Aside from being trimmed a little on the ends, it ends up in almost a perfect spot and tops right at the bottom of my C-body radiator.
The only reason I can't run it as-is unfortunately is that my lower radiator outlet is 1.75" versus all my other connections, which are 1.5".
I'm going to run the silicone adapter to go back to 1.5" on the radiator and cut the bend to add a prettier turn on the factory lower hose (like a splice and a turn in one shot).
My Thunderbird radiator fan is a pretty decent fit also. I'm going to need to make some small aluminum L-brackets to use the factory attachment points on the radiator as support and cut the shroud a bit to bring it closer in.
I also started adding my Z-bar. I'm really happy everything is clearing the headers at this point. This will make the install that much easier. I was budgeting for a Hyrdraulic set up to be needed, but the SB Lakewood/TTI's are existing well together.
I'll take some pictures tomorrow. It's looking to be a pretty tidy engine bay.
Re: Let the Hemi swap begin [Re: AlexP] #1577476
11/03/14 03:17 AM
11/03/14 03:17 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey what alternator and power steering pump are you using?
Part numbers?
thanks!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: RylisPro] #1577477
11/03/14 03:42 AM
11/03/14 03:42 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I don't know by part number, but I know by application.
The alternator is a re-manned 05-08 5.7 car unit and my ps pump is an 03-08 5.7 car.
I'll use an external reservoir on the PS pump. Just factory stuff mounted to the fender. The easy thing to do would be to get a Jeep SRT8 Powersteering pump, with the built in reservoir...but I've not come across one for thr right price yet.
Re: Let the Hemi swap begin [Re: AlexP] #1577478
11/03/14 03:58 AM
11/03/14 03:58 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Cool!
So 2008 5.7 stuff will work on a 6.4?
Good to know!
I'm a newb when it comes to Gen III stuff haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
