Page 3 of 3 1 2 3
Re: 833 tranny fluid [Re: 66HEMICORONET] #1576868
02/13/14 07:35 PM
02/13/14 07:35 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Anyone have any recommendations as to the type of lube to use in my 4 speed tranny? We've heard some say synthetic and others not. Any opinions?
IMHO, if your 4spd had ATF in it, run it with that if you so desire, if it had gear oil (80w-90) run that, personally over the last 30 years I've always run gear oil in my Mopar 4spds I've seen too many guys over the years that say "The FSM says ATF", and they switch out the gear oil, and find that one or more several things happen, the tranny craps out big time, or it leaks like a sieve with the ATF, or it shifts like crap....so after you cut thru the "mustard" of this thread, and pic your poison, report back with your opinion
Mike
Re: 833 tranny fluid [Re: dan9] #1576869
02/13/14 09:01 PM
02/13/14 09:01 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I bought mine from Passon's last year. He told me to run 80/90w non-synthetic.
he told
You to run any 80/90? Does he not sell his fluid any more? I run his and it's about the weight of 5/30w
Re: 833 tranny fluid [Re: ThermoQuad] #1576870
02/13/14 09:02 PM
02/13/14 09:02 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Call Jamie Passon- Passon Performance - you know the 4 and 5 speed guy. He has his own proprietary transmission lubricant for mopar 4 speeds. There is a significant difference between his lubricant and the off the shelf products that many will recommend. btw I torture tested the Passon product and the OFTPs and his by far performed the best.
Common sense is a flower that does not grow in everybody's garden
Re: 833 tranny fluid [Re: John_Kunkel] #1576871
02/13/14 10:27 PM
02/13/14 10:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ever wonder why Chrysler developed the "slick shift" modification for the 833?
Yeah, so lesser mortals could try to keep up with Ronnie Sox.
NOT FOR STREET USE.
Don't be the exception.
Re: 833 tranny fluid [Re: Supercuda] #1576872
02/14/14 01:03 AM
02/14/14 01:03 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
NOT FOR STREET USE.
I always thought 833s powershifted nice
Re: 833 tranny fluid [Re: ademon] #1576873
02/14/14 12:48 PM
02/14/14 12:48 PM
pa.
dan9 Offline
dan9  Offline
pa.
Yes that is what he said. Any 80/90w non-synthetic. He did not try to sell me his or even mention that he had his own type.
Re: 833 tranny fluid [Re: Supercuda] #1576874
02/14/14 02:43 PM
02/14/14 02:43 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
NOT FOR STREET USE.
Here is a little secret...
Sox ran a Toploader in a lot of those cars...
MB
Re: 833 tranny fluid [Re: dan9] #1576875
02/14/14 03:02 PM
02/14/14 03:02 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
OK thanks maybe ill go with the Red line MTL next
Re: 833 tranny fluid [Re: HPMike] #1576876
02/14/14 03:06 PM
02/14/14 03:06 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
NOT FOR STREET USE.
MB
Not in class racing.
Page 3 of 3 1 2 3
