Re: 9 inch ford
[Re: cesar perez]
#1575960
02/08/14 06:46 PM
02/08/14 06:46 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
Depends largely on the carrier I think....There were a ton of variations depends what it is out of?
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
Re: 9 inch ford
[Re: cesar perez]
#1575962
02/10/14 06:30 PM
02/10/14 06:30 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
iam in the prosses of putting a ford 9 inch rear together with a full spool - 456-gears and 35 spline axles but iam trying to use the stock carrier what is the hp rating on a stock carrier
Most 35 spline spools require a 3.25" bearing case. There isn't a stock 3.25" bearing case and 3.0625 was the largest bearing from the factory.
