9 inch ford #1575959
02/08/14 06:40 PM
02/08/14 06:40 PM
florida dade
cesar perez Offline OP
florida dade
iam in the prosses of putting a ford 9 inch rear together with a full spool - 456-gears and 35 spline axles but iam trying to use the stock carrier what is the hp rating on a stock carrier
Re: 9 inch ford [Re: cesar perez] #1575960
02/08/14 06:46 PM
02/08/14 06:46 PM
Milwaukee, WI
moparjimbo Offline
moparjimbo  Offline
Milwaukee, WI
Depends largely on the carrier I think....There were a ton of variations depends what it is out of?
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire
1973 Challenger - 572 Indy Hemi 860HP
1975 Trailduster Convertible, 440
1967 Plymouth Fury Police Pursuit 2DR 505 Stroker
2004 Neon SRT4 modded
www.milwaukeemopar.com
Re: 9 inch ford [Re: moparjimbo] #1575961
02/08/14 06:49 PM
02/08/14 06:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
unless it is a nodular I wouldn't bother. you can find a good after market pretty cheap. and it also depends on what kind of power weight etc.
Re: 9 inch ford [Re: cesar perez] #1575962
02/10/14 06:30 PM
02/10/14 06:30 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Most 35 spline spools require a 3.25" bearing case. There isn't a stock 3.25" bearing case and 3.0625 was the largest bearing from the factory.
Re: 9 inch ford [Re: 446acuda] #1575963
02/10/14 06:52 PM
02/10/14 06:52 PM
mi
dirty magnum Offline
mi
Richmond sells a 35 spline spool that fits the small bearing carrier
Re: 9 inch ford [Re: dirty magnum] #1575964
02/10/14 08:14 PM
02/10/14 08:14 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
So do Mark Williams, it's a very nice piece!
Alan Jones
